I am recording video using a GoPro.
Resolution is 2.7k (2704x1520)
60fps
I am using Vegas Movie Studio 16 Platinum.
I only see output settings for 4k and 1080p.
So, I think the render is taking a lot longer since it is rescaling the frames.
How can I output without resize and just stick to 2.7k output video ?
Make Movie -> Advanced Options?
MAGIX AVC/AAC MP4 ?
MAGIX HEVC/AAC MP4 ?
	I do not use the prog but I would have thought that there would be a 'user-defined' output option.
 Is there a '[--]' button alongside the standard output dropdown ?
 However you are dealing with 1. an older version of the program and 2. a more basic/standard program. Such options might only be available in higher products such as Vegas Pro.
	Yea, I can manually edit an existing option, but it blows my mind there isn't a defined setting for 2.7k.
 There are dozens of choices for 4k 1080p 720p etc.
 Is 2.7k proprietary to GoPro only? Even still, that is a major segment of video creation.
	Well that 2.7k may be a 'standard' for Go Pro it is not a standard output format. So, yes, it is proprietary.
 I just read a guide that states that one of the advantages of 2.7k is for zooming in on the image.
 You must consider where your final video is viewed. So a standard 1080p or even 4k is more appropriate.
  Optimization tips/tricks for editing 4k on Movie Studio 16 Platinum ?By GoodEnough in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2020, 14:17
  Vegas Movie Studio and interlaced contentBy smartel in forum Newbie / General discussionsReplies: 45Last Post: 8th May 2019, 21:09
  How you set your PC to speed up Movie Studio Platinum 13?By arpantoja in forum EditingReplies: 6Last Post: 4th Jan 2019, 16:30
  Converting AVI From Vegas Movie Studio to GIFBy pone44 in forum EditingReplies: 10Last Post: 18th Sep 2018, 09:55
  Vegas Movie Studio vs Adobe Premiere ElementsBy rfe777 in forum EditingReplies: 12Last Post: 6th Dec 2017, 11:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
