I have a (smartphone) video which was originally recorded with 30fps.
Sometimes scenes are stuttering a little.
So when I re-encode these videos (with the same codec H.264) but increase the fps up to 60 does this help to repair stuttering?
In order words: does ffmpeg really calculate the additional new frames as intermediate half-way steps between the two existing frames?
Or are are the new frames more or less just added as stupid dummy frames?
Normally the new added frames are just duplicate frames ( or sometimes effectively duplicates from timestamp changes), unless you use something like -vf minterpolate (but it has some bugs and memory leak)
https://ffmpeg.org/ffmpeg-filters.html#minterpolate
However , smartphone videos are usually VFR (variable frame rate) . 30 FPS isn't really 30FPS . There are sections where the fps will drop - those sections will stutter.
You can check with mediainfo (view=>text) it will usually report a min and max framerate, or -vf vfrdet in ffmpeg
https://ffmpeg.org/ffmpeg-filters.html#vfrdet
AI Interpolation of NASA footage (Smoothing/Increasing Fps)
By Dutchsteammachine in forum Newbie / General discussionsReplies: 33Last Post: 19th Jul 2020, 15:19 -
Is it possible to repair a video from which ffmpeg says this error?
By Chemist116 in forum RestorationReplies: 0Last Post: 11th Jun 2018, 13:11 -
Is there a way to repair damaged video with ffmpeg?
By Chemist116 in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2018, 16:13 -
Slow video transcoding ffmpeg h264 0.6 fps
By www-data in forum Video ConversionReplies: 12Last Post: 24th May 2018, 00:58 -
FFMPEG Only Converting at 1.5-2 FPS
By aaronc1976 in forum Video ConversionReplies: 4Last Post: 29th Aug 2016, 15:16
