  1. I have a set of 8 AVI files - mediainfo details below.
    I am using VSDC and encoding with the hardware accelerated NVIDIA H265 profile (Normal quality CRF 30 AAC 192) into a single MKV file
    The individual AVI files all have a progressive audio delay ranging from 1-2 seconds. If I alter the frame rate with the AVI Frame Rate Adjust v1.00 tool from 30 to 29.8 this corrects the delay. But adding those corrected AVI files to the MKV workflow above still results in an out of sync MKV.
    Is there a better solution to this problem? Should I change the framerate from within the VSDC encoder profile and not alter the AVI files beforehand, or is there a better way of pre treating the AVI files before I load them up into the VSDC timeline? Note the audio delay problem is not constant, it starts off at about 1 second and progressively drifts towards 2 seconds towards the end of each 5 min AVI file.
    General
    Complete name : MOV00000.AVI
    Format : AVI
    File size : 823 MiB
    Duration : 5 min 2 s
    Overall bit rate : 22.9 Mb/s
    Video
    Format : JPEG
    Codec ID : MJPG
    Bit rate : 22.3 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.360
    Stream size : 802 MiB (97%)
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : 1
    Duration : 5 min 1 s
    Bit rate mode : Constant
    Bit rate : 512 kb/s
    Channel(s) : 1 channel
    Sampling rate : 32.0 kHz
    Bit depth : 16 bits
    Stream size : 18.4 MiB (2%)
    Alignment : Aligned on interleaves
    Interleave, duration : 1004 ms (29.91 video frames)
  2. Try to encode with 29.97fps
  3. That didn’t help I’m afraid but thanks for the suggestion.
    Apr 2007
    Australia
    Hi.
    With 'AVI Frame Rate Adjust' tool it looks like the change to the audio is only written in the header. Nothing is changed in the video/audio stream.
    That info is not being honored by VSDC.
    I wrote this batch file. You'll need ffmpeg.exe in the folder with the batch file and videos.
    Might be worth experimenting with. If the video starts playing with a 1 second audio delay and then drifts out to 2 seconds then you may get a video out with matching start times.
    I'm not saying the drift won't happen.
    Drag and drop a video onto the batch file.
    AUDIO Delay DROP v02.cmd
    @echo off
    if not exist NEW\*.* md NEW
    echo.
    echo  Output will be in the \NEW folder.
    echo  Enter the figure in "seconds.milliseconds"
    echo  with a plus or minus sign in front.
    echo.
    echo  The change can be negative or positive.
    echo  e.g.
    echo  -0.500  -^> half a second
    echo  -0.250  -^> a quarter of a second
    echo  +0.280  -^> two hundred and eighty milliseconds
    echo  +1.500  -^> one and a half seconds
    echo.
    echo  If the audio is playing too late use negative.
    echo  If the audio is playing too soon use positive.
    set /p offset=Enter the change:
    :Loop
    ffmpeg.exe -i %1 -itsoffset %offset% -i %1 -vcodec copy -acodec copy -map 0:0 -map 1:1  -y "NEW\%~nx1"
    shift
    if not %1=="" goto :Loop
    There are a number of converters here.
    https://topalter.com/windows/46112/avi-frame-rate-changer/alternatives
    Maybe one of them will do what you want.
    Have fun.
    Cheers
