    Jul 2010
    Lostik
    How to make EIA-608/EIA-708
    General
    Complete name : D:\1.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 63.7 MiB
    Duration : 3 min 24 s
    Overall bit rate : 2 618 kb/s
    Law rating : TV-14 (DL)
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=4, N=60
    Codec ID : avc1
    Bit rate : 2 448 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 FPS
    Minimum frame rate : 29.412 FPS
    Maximum frame rate : 30.303 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.089
    Stream size : 59.5 MiB (93%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate mode : Constant
    Bit rate : 160 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 spf)
    Compression mode : Lossy
    Stream size : 3.89 MiB (6%)
    Default : Yes
    Alternate group : 1
    Text #1
    Format : EIA-608
    Muxing mode : SCTE 128 / DTVCC Transport
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    Encoded stream size : 0.00 Byte (0%)
    Text #2
    Format : EIA-608
    Text #3
    Format : EIA-708
    Text #4
    Format : EIA-708
    Aug 2006
    I have not seen any consumer software that includes the ability to add EIA 608 or EIA 708 ATSC broadcast closed captions to video files.
    Adding support for embedding CEA/EIA-608 closed captions in the video GOP user data has been on the to-do list for ffmpeg for a long time but I have not heard that there has been any progress in that area.
    Some consumer software exists for creating source files that broadcasters can use to add ATSC captions, MovieCaptioner.
    [Edit]If you have a few thousand dollars to spend on professional closed captioning software, look at PixelTools
    Jul 2010
    Lostik
    about 10 years ago, I got free software that includes the ability to add EIA608/EIA708 CC to video , but now I forgot the name. lol
