  1. I want to rip a 1980's TV series from a 576p DVD boxset. It was shot on film with quite a bit of grain. Episodes run around 50m and are split into two .VOB files with a total up to 2GB per episode. There are about four episodes per 7,2GB DVD. I want to focus on a nice quality which keeps much of the grain and relatively small file sizes between 400 and 500MB. I have a 16GB Intel Core i5-8400 2,80GHz 64 bit Windows 10 with a 6GB 1660 TI. I'd like to keep encoding to at most 3 hours per episode.
    Is there (a guide with) a recommended setup of software, codec and settings for this particular type of content?
    General
    Complete name                            : E:\VIDEO_TS\VTS_02_1.VOB
    Format                                   : MPEG-PS
    File size                                : 1 024 MiB
    Duration                                 : 26 min 41 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 5 364 kb/s
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings                          : CustomMatrix
    Format settings, BVOP                    : No
    Format settings, Matrix                  : Custom
    Format settings, GOP                     : N=6
    Format settings, picture structure       : Frame
    Bit rate mode                            : Variable
    Bit rate                                 : 5 065 kb/s
    Maximum bit rate                         : 7 500 kb/s
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 25.000 FPS
    Standard                                 : PAL
    Scan type                                : Interlaced
    Scan order                               : Bottom Field First
    Bits/(Pixel*Frame)                       : 0.489
    Time code of first frame                 : 01:00:00:00
    Time code source                         : Group of pictures header
    GOP, Open/Closed                         : Closed
    Stream size                              : 967 MiB (94%)
    Color primaries                          : BT.601 PAL
    Transfer characteristics                 : BT.470 System B/G
    Matrix coefficients                      : BT.601
    Audio
    ID                                       : 189 (0xBD)-128 (0x80)
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Commercial name                          : Dolby Digital
    Muxing mode                              : DVD-Video
    Duration                                 : 26 min 40 s
    Bit rate mode                            : Constant
    Bit rate                                 : 192 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 SPF)
    Stream size                              : 36.6 MiB (4%)
    Service kind                             : Complete Main
    Text
    ID                                       : 189 (0xBD)-32 (0x20)
    Format                                   : RLE
    Format/Info                              : Run-length encoding
    Duration                                 : 26 min 38 s
    Delay relative to video                  : 960 ms
  2. If it's recorded on film that that means it's sped up. Slow it down. Some programs can do that
