  1. Hi everybody and thanks for the good work !
    I would like to have your advice before purchasing the Startech USB3HDCAP. My goal is to capture my old PC Voodoo 2 VGA output and record it with OBS Studio. I will need to capture different definitions depending the game I will play.
    Since it's pretty expensive, do you think this device is a good idea ? Can it record 60fps from a VGA output or only from a HDMI ?
    Thank you very much for your help !
  2. I have bought it anyway, used and half price. I will let people know if it works fine.
  3. Well it is working very well !
  4. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Thanks for reporting back. The info could be useful for someone else in the future.
    My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
