Results 1 to 11 of 11
  1. hello community
    I am downloading from this page https://// with Stream Recorder, but it usually downloads with errors
    sometimes seconds are skipped in the broadcast
    is there a way to download with as few errors as possible with ffmpeg or some other tool?
  2. I only downloaded a few minutes using each but they were clean:
    ffmpeg -loglevel error -stats -i "https://stream-02.sv4.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyBgWg_A)/dm/3/x7gy059/d/live-4.m3u8#cell=lsv4" -c copy output.mp4
    youtube-dl --verbose --hls-use-mpegts --no-part "https://stream-02.sv4.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyBgWg_A)/dm/3/x7gy059/d/live-4.m3u8#cell=lsv4"
  3. Originally Posted by jagabo View Post
    with ffmpeg I get this error
    C:\Widevine>ffmpeg -loglevel error -stats -i "https://stream-01.nyc.dailymotion.
    cell=lnyc" -c copy output.mp4
    [tls @ 000000301e4e64c0] Creating security context failed (0x80090326)
    https://stream-01.nyc.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyB
    gWg_A)/dm/3/x7gy059/d/live-4.m3u8#cell=lnyc: Unknown error occurred
    thanks
  4. your url ends in "cell=lnyc", the one I gave ends in "cell=lsv4".
  5. with youtube-dl it shows me the following error, same with ffmpeg
    HTML Code:
    Microsoft Windows [Versión 6.3.9600]
    (c) 2013 Microsoft Corporation. Todos los derechos reservados.
    C:\Widevine>youtube-dl --verbose --hls-use-mpegts --no-part "https://stream-02.s
    [debug] System config: []
    [debug] User config: []
    [debug] Custom config: []
    [debug] Command-line args: ['--verbose', '--hls-use-mpegts', '--no-part', 'https
    )/dm/3/x7gy059/d/live-4.m3u8#cell=lsv4']
    [debug] Encodings: locale cp1252, fs mbcs, out cp850, pref cp1252
    [debug] youtube-dl version 2021.06.06
    [debug] Python version 3.4.4 (CPython) - Windows-8.1-6.3.9600
    [debug] exe versions: ffmpeg N-103193-gc60b76d0c8-20210809, [url=https://www.videohelp.com/software/ffmpeg]ffprobe[/url] N-103193-gc6
    0b76d0c8-20210809
    [debug] Proxy map: {}
    [generic] live-4: Requesting header
    [generic] live-4: Downloading m3u8 information
    [debug] Default format spec: bestvideo+bestaudio/best
    [debug] Invoking downloader on 'https://stream-02.sv4.dailymotion.com/sec(O-7bth
    6lxCIslucX64-RYzwDGPg8UB1g1K3RyBgWg_A)/dm/3/x7gy059/d/live-4.m3u8'
    [download] Destination: live-4-live-4.mp4
    [debug] ffmpeg command line: ffmpeg -y -loglevel verbose -headers "Accept-Langua
    ge: en-us,en;q=0.5
    Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML,
     like Gecko) Chrome/72.0.3597.0 Safari/537.36
    Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
    Accept-Encoding: gzip, deflate
    " -i "https://stream-02.sv4.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g
    1K3RyBgWg_A)/dm/3/x7gy059/d/live-4.m3u8" -c copy -f mpegts "file:live-4-live-4.m
    p4"
    ffmpeg version N-103193-gc60b76d0c8-20210809 Copyright (c) 2000-2021 the FFmpeg
    developers
      built with gcc 10-win32 (GCC) 20210408
      configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-conf
    ig=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw
    32 --enable-gpl --enable-version3 --disable-debug --disable-w32threads --enable-
    pthreads --enable-iconv --enable-libxml2 --enable-zlib --enable-libfreetype --en
    able-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-libvorbi
    s --enable-opencl --enable-libvmaf --enable-vulkan --disable-libxcb --disable-xl
    ib --enable-amf --enable-libaom --enable-avisynth --enable-libdav1d --enable-lib
    davs2 --disable-libfdk-aac --enable-ffnvcodec --enable-cuda-llvm --enable-libgls
    lang --enable-libgme --enable-libass --enable-libbluray --enable-libmp3lame --en
    able-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-lv2 --
    enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-lib
    openjpeg --enable-librav1e --enable-librubberband --enable-schannel --enable-sdl
    2 --enable-libsoxr --enable-libsrt --enable-libsvtav1 --enable-libtwolame --enab
    le-libuavs3d --disable-libdrm --disable-vaapi --enable-libvidstab --enable-libx2
    64 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libzimg --extra-
    cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-ld
    exeflags= --extra-libs=-lgomp --extra-version=20210809
      libavutil      57.  3.100 / 57.  3.100
      libavcodec     59.  4.101 / 59.  4.101
      libavformat    59.  4.101 / 59.  4.101
      libavdevice    59.  0.100 / 59.  0.100
      libavfilter     8.  1.103 /  8.  1.103
      libswscale      6.  0.100 /  6.  0.100
      libswresample   4.  0.100 /  4.  0.100
      libpostproc    56.  0.100 / 56.  0.100
    [tcp @ 000000ace7816740] Starting connection attempt to 198.54.200.188 port 443
    [tcp @ 000000ace7816740] Successfully connected to 198.54.200.188 port 443
    [tls @ 000000ace7816840] Creating security context failed (0x80090326)
    [url]https://stream-02.sv4.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyB[/url]
    gWg_A)/dm/3/x7gy059/d/live-4.m3u8: Unknown error occurred
    ERROR: ffmpeg exited with code 1
      File "__main__.py", line 19, in <module>
      File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\ytdl-org\tmpkqxnwl
    31\build\youtube_dl\__init__.py", line 475, in main
    31\build\youtube_dl\__init__.py", line 465, in _real_main
    31\build\youtube_dl\YoutubeDL.py", line 2069, in download
    31\build\youtube_dl\YoutubeDL.py", line 808, in extract_info
    31\build\youtube_dl\YoutubeDL.py", line 815, in wrapper
    31\build\youtube_dl\YoutubeDL.py", line 847, in __extract_info
    31\build\youtube_dl\YoutubeDL.py", line 881, in process_ie_result
    31\build\youtube_dl\YoutubeDL.py", line 1692, in process_video_result
    31\build\youtube_dl\YoutubeDL.py", line 1976, in process_info
    31\build\youtube_dl\YoutubeDL.py", line 1915, in dl
    31\build\youtube_dl\downloader\common.py", line 366, in download
    31\build\youtube_dl\downloader\external.py", line 64, in real_download
    31\build\youtube_dl\downloader\common.py", line 165, in report_error
    31\build\youtube_dl\YoutubeDL.py", line 628, in report_error
    31\build\youtube_dl\YoutubeDL.py", line 590, in trouble
    with ffmpeg
    HTML Code:
    [tls @ 000000c2a2c554c0] Creating security context failed (0x80090326)
    gWg_A)/dm/3/x7gy059/d/live-4.m3u8#cell=lsv4: Unknown error occurred
  6. streamlink "https://stream-03.nyc.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyBgWg_A)/dm/3/x7gy059/d/live-4.m3u8#cell=lnyc" best -o video.ts
    [cli][info] Loaded config from deprecated path, see CLI docs for how to migrate: C:\Users\X\AppData\Roaming\streamlink\streamlinkrc
    [cli][info] Found matching plugin hls for URL https://stream-03.nyc.dailymotion.com/sec(O-7bth6lxCIslucX64-RYzwDGPg8UB1g1K3RyBgWg_A)...m3u8#cell=lnyc
    [cli][info] Available streams: live (worst, best)
    [cli][info] Opening stream: live (hls)
    [download][video.ts] Written 14.2 MB (32s @ 443.6 KB/s)...
  7. Originally Posted by LZAA View Post
    I are downloading with streamlink
    thank you very much
  8. Originally Posted by LZAA View Post
    sorry I'm bothering you again
    I want to download streaming from this link https://cloud.streamingconnect.tv:455/televen/televenweb.m3u8, but when I put the code in streamlink I get an error
    HTML Code:
    Windows PowerShell
    Copyright (C) 2014 Microsoft Corporation. Todos los derechos reservados.
    PS C:\Users\ADMINPC> streamlink "https://cloud.streamingconnect.tv:455/televen/televenweb.m3u8" best -o video.ts
    [cli][info] Found matching plugin hls for URL https://cloud.streamingconnect.tv:455/televen/televenweb.m3u8
    error: Unable to open URL: https://cloud.streamingconnect.tv:455/televen/televenweb.m3u8 (HTTPSConnectionPool(host='cloud.streamingconnect.tv', port=455): Max retries exceeded with url: /televen/televenweb.m3u8 (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1125)'))))
    the url is http://www.televen.com/enlinea/
  9. Content does not open in the browser.
    Jan 2021
    Argentina
    HTML Code:
    Windows PowerShell
    Add --http-no-ssl-verify
    streamlink --http-no-ssl-verify "https://cloud.streamingconnect.tv:455/televen/televenweb.m3u8" best -o video.ts
  11. Originally Posted by lfer94 View Post
    HTML Code:
    Windows PowerShell
    thank you very much I needed that code now it runs fine
