I'm experimenting with restoring an old film from the 30s to some extent which was apparently "lost". The only version I can find looks to have had a terrible transfer. It's been badly encoded to 29.97p, where it seems every other frame was duplicated. Once that's been rectified I'm left with a 20p source that's been badly blended. 3 out of 5 frames seem to be blended, plus It's been deinterlaced as well to compound the issue.
I'm not great with Avisynth but I've been experimenting. The only things that yield some kind of results are to remove the duplicate frames, and then maybe to remove the bulk of the blended frames (which results in a whopping 9.5fps, and then maybe re-interpolate new frames from that and clean up the cut-scenes.
If anyones got any better ideas to try and claw back something from the blended frames I'm open to ideas! Here's some of the worst blending from a pan.Code:LWLibavVideoSource("<file>", cache=false, prefer_hw=2) # remove duplicate frames AssumeFPS(30,sync_audio=true) TDecimate(mode=1, cycle=3,denoise=false,noblend=true) # remove ghosting / blended frames srestore(omode=6, mode=6, thresh=12)
[Attachment 60387 - Click to enlarge]
And a 10 second sample from the original file.
https://mega.nz/file/VKZEzByS#ArscTqzWEU1M_CkQkYeGYOn6b6sQIvU6pSdgYDqLn-M
I seem to have had some success with the RestoreFPS plugin, but in all honesty I can't work out how it works from the documentation and it's pure trial and error in my script.
If anyone has played with it in the past and can give me some hints that would be very helpful.
Code:#DirectShowSource("\\nas\Restoration\source\Where's That Fire (1939)\Where's That Fire (1939) 480p MP3.avi", seek=true, audio=true, video=true, convertfps=false, seekzero=false, timeout=60000, logmask=35) LWLibavVideoSource("\\nas\Restoration\source\Where's That Fire (1939)\sample.avi", cache=false, prefer_hw=2) # remove duplicate frames AssumeFPS(30,sync_audio=true) c = TDecimate(mode=1, cycle=3,denoise=false,noblend=true) # remove blending function phase(clip c, float phi){ c RestoreFPS(25, phi) } Animate(0,100,"phase",0.0,0.3) #SRestore(frate=24, mode=1, thresh=12)
[Attachment 60389 - Click to enlarge] -
This properly gets rid of the telecine (i.e., doubled frames)
Code:tfm(display=false) tdecimate(display=false,mode=0,cycleR=2,cycle=6)
Indeed there are a lot of issues. The duplicated frames I already had resolved. If i can minimise the blending then perhaps I can work on the missing frame issue later. Main thing at the moment is the awful blends.
Windows NT and Sony DVCAM DSR-20P video capture
By markpritchett in forum Newbie / General discussionsReplies: 10Last Post: 12th Jun 2021, 02:52 -
Undo blend-deinterlace?
By embis2003 in forum Video ConversionReplies: 4Last Post: 10th Oct 2020, 19:24 -
Sony DSR-20P not recognized by Adobe/BM Media Express when using SDI cable
By gvemdr in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2019, 06:58 -
Converting mixed 24p/30p (encoded as 30p) to 60p
By Luke M in forum Video ConversionReplies: 0Last Post: 3rd Jan 2019, 22:18 -
Blender - Subtitling with 'blend-sub' add-on
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 29th Sep 2018, 19:13
