Hi
Can you recommend a software able to repair the stuttering in the video below, please? Starting from 2:17:38.
https://www.youtube.com/watch?v=BMJfDzJghZE
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Frames are misordered, and the pattern is not regular. There does not appear to be any missing frames
You'd need to move/edit them to correct location (times) in video editor. -
I didn't bother to download it, but I don't think there is an automated way to fix it. If someone gave me the actual video, I'd first try to simply replace the jumps with a duplicate of the previous frame. If the jumps are two-frames long, then replace the second jump with a duplicate of the frame after the discontinuity.
If the discontinuities are only one frame long, you actually CAN repair that automatically using this script I developed several years ago:
Finding individual "bad" frames in video; save frame number; or repair -
I did have a look at it and frames are just out of order. No duplicates or drops. You just need to put them in their proper place. e.g. ripple cuts & inserts
Video constantly stuttering/lagging on MPC-HC
By synnchan in forum Newbie / General discussionsReplies: 17Last Post: 28th Jun 2021, 17:33 -
How to scan a video file for lost frames/stuttering?
By Shadowlord in forum RestorationReplies: 23Last Post: 7th Nov 2019, 17:39 -
A/V sync problem and stuttering while playing 4k video in MPC-BE
By hari4698 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2019, 05:37 -
can't fix choppy/stuttering Video Playback
By Gwar in forum Software PlayingReplies: 11Last Post: 8th Feb 2019, 18:47 -
Stuttering video after converting MP4 H.264 to VOB
By guy24s in forum Video ConversionReplies: 14Last Post: 4th May 2017, 05:10
