I have a bunch of MP4 files that I am editing with Adobe Premiere Elements 14 (to chop out unwanted segments) and then using ffmpeg to add chapters and some metadata. Some of those segments are at the beginning of the file, which I suspect may be leading to this error when using ffmpeg:
When I play these converted MP4s in VLC, they seem to be fine. When I Google the message, some people recommend using the "-ignore_editlist 1" switch. But, I can't seem to find any instances where people had some type of problem when the message occurred and then that problem went away with the "-ignore_editlist 1" switch. They acknowledge that there is something called an "edit list", but, I don't find any explanation of what it is or does.Code:st: 0 edit list: 1 Missing key frame while searching for timestamp: 0 st: 0 edit list 1 Cannot find an index entry before timestamp: 0.
So, what does this message mean, when/where will this reveal itself as a problem, and, what does "ignoring" the editlist accomplish?
Edit: it seems that this message happens when I edit the MP4 with Premiere Elements and chop off a portion of the beginning of the file before the ffmpeg conversion. I can mitigate this by using ffmpeg to chop off part of the beginning, but, I am still interested in finding out what problems this error might cause.
Results 1 to 1 of 1
Programs missing from frontpage's " Latest software downloads"-section
By Hurda in forum FeedbackReplies: 9Last Post: 9th Dec 2020, 03:50 -
nvenc_hevc encoding "B-adapt disabled" message - how to rectify?
By hydra3333 in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2019, 15:59 -
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 10:09 -
Error message:" That program is not allowed to be recorded" Channel 24.3
By carltomd in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Oct 2017, 12:00 -
Premiere Pro CC 2015 - "Step Forward 1 Frame" doesn't jump to next frame
By xyron in forum EditingReplies: 1Last Post: 30th Nov 2016, 09:05
