Using staxrip 2.8.0 – I want to encode vob files to xvid avi. In the encoder settings when I select ffpeg-xvid and avi I get the following error message – ‘the encoder outputs ‘mkv’ but the container AVI supports only avi, mp2, mp3, ac3, mpa, wav’. I don’t understand why I get the error message or what it means. I have been previously using staxrip 1.2.2.0 and used the same settings without problems. I am not rencoding the orginal ac3 audio. Is it possible to encode vob files to xvid avi using staxrip 2.8.0. Please help.
You can also use clever Ffmpeg-GUI to recode vob (mpeg2) to xvid an mux the new videostream with the original audiostream to AVI.
Thanks for the replies.
I have installed clever Ffmeg-GUI, giving it ago and still getting use to it.
Using clever Ffmpeg-GUI can I select a predefined bitrate output when Encoding VOB files to xvid? -
Use the bitrate you like. For the beginning the preselected bitrate should be fine.
Match AVI file format settings
By swanescalona in forum Video ConversionReplies: 10Last Post: 3rd Jan 2025, 19:11 -
Staxrip. Encoding mpeg2 to xvid. Predefined bitrate not correct.
By fubar87 in forum Video ConversionReplies: 0Last Post: 20th Dec 2019, 10:38 -
DVDx XviD 2-pass settings?
By iosman in forum Newbie / General discussionsReplies: 3Last Post: 29th Sep 2019, 17:39 -
StaxRip v2.0.0.1 Beta fails to convert .avi files
By RHawk in forum Video ConversionReplies: 4Last Post: 13th May 2019, 01:44 -
Staxrip settings to get smaller files with NVEnc?
By bizzybody in forum Video ConversionReplies: 6Last Post: 17th Oct 2017, 17:28
