I have a three-disc wrestling DVD, which I want to put on my media server. Pretty simple. Rip each disc, mux them together, shift it into the correct folder. Done.
Except, playback looks super weird after a while. Turns out, disc 3 is BFF and the other two are TFF. Because...reasons, I guess?
So...what's the best solution here? Re-encoding D3 to flip the fields (not sure how) and muxing? Re-encoding the lot somehow?
Results 1 to 9 of 9
Some containers allow for changing video properties mid-stream. Transport streams, for example. Not all players will respond correctly so it's best to convert the field order. That can be in AviSynth done with:
orCode:SeparateFields() Trim(1,0) Weave()
Code:Crop(0,0,-0,-1) # take one line off the bottom AddBorders(0,1,0,0) # add one line at the top
I did try the crop-and-add-borders thing with FFMPEG, but I ended up with a file that was 17GB and still incorrectly interlaced:
Code:ffmpeg -i disc3.mkv -vcodec mpeg2video -qscale:v 2 -acodec copy -vf "crop=720:479:0:1,pad=720:480:0:1" -aspect 16:9 -force_key_frames "chapters" disc3fixed.mkv
You can't crop by 1 pixel vertically for subsampled 4:2:0 material, such as DVD-video .
ffmpeg -i disc3.avs -i disc3.mkv -vcodec mpeg2video -qscale:v 4 -acodec copy -flags +ilme+ildct -top 0 -aspect 16:9 -force_key_frames 1:"chapters" -map v:0 a:1 disc3fixed.mkv
Code:LwLibAvVideoSource("disc3.mkv") AssumeTFF() SeparateFields() Trim(1,0) Weave()Code:disc3.avs: Unknown error occurred
I would not re-encode.
MPEG-2 video, even as a plain elementry stream, has an inherent field order flag for every GOP (meaning it is repeated constantly and can change between GOPs). It just needs to be respected during playback.
Therefore, I think the most effective method would be to force the player to refer to the field order flag of the underlaying MPEG-2 video stream – rather than a field order flag of the mkv container.
Maybe it is as simple as removing the mkv field order flag from the file.
If that doesn't do the trick then there is the option of setting the mkv field order flag to "2" which means "undetermined field order".
Try that first before you re-encode. -
The MKV already doesn't contain a field order flag, as far as I can tell. The Emby LG TV and Samsung TV apps both handle it just fine, but on my NVIDIA Shield it looks awful.
Yep, that's what it was. But forcing keyframes on the chapters isn't working:
Code:ffmpeg\ffmpeg.exe -i disc3.avs -i disc3.mkv -vcodec mpeg2video -qscale:v 4 -acodec copy -flags +ilme+ildct -top 0 -aspect 16:9 -force_key_frames 1:"chap ters" -map 0:v -map 1:a disc3fixed.mkv
Code:Invalid duration specification for force_key_frames: 1:chapters
So how do I use the chapters from the MKV file as the keyframe points for encoding?
need help - 3D muxing from 2-field MKV rips to .TS
By oleus23 in forum Video ConversionReplies: 2Last Post: 14th May 2021, 12:37 -
Field-blended video with messed up field order
By bruno321 in forum RestorationReplies: 1Last Post: 23rd Feb 2021, 10:34 -
Same device serving different field orders?
By bigass in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2021, 10:37 -
How Merge 1 Video to 100 Videos (Intro + Multiple Main Videos) help
By Squid Ward in forum EditingReplies: 0Last Post: 4th Sep 2020, 10:27 -
Hauppauge USB-Live 2: Top field or bottom field?
By billybatts in forum Capturing and VCRReplies: 3Last Post: 9th May 2020, 04:57
