How do you convert, using Vidcoder, video files which have mixed sequences in anamorphic and IMAX?
I think I did in the past, but there's a file I have, which was converted from the original Bluray down to 12GB, keeping the original screen sizing.
But I don't know if there's a way to setup that in Vidcoder. This is what Mediainfo shows for the file
General
Unique ID : 254421617144903923509816295445738641635 (0xBF67D23356ED83F797D5CB5B2EB958E3)
Complete name : J:\XXYYWW IMAX Edition 720p BluRay DTS x264-TayTO.mkv
Format : Matroska
Format version : Version 4
File size : 11.5 GiB
Duration : 2 h 49 min
Overall bit rate : 9 746 kb/s
Movie name : Interstellar 2014 IMAX Edition 720p BluRay DTS x264-TayTO
Encoded date : UTC 2015-03-24 14:07:14
Writing application : mkvmerge v7.6.0 ('Garden of Dreams') 64bit built on Feb 8 2015 13:04:34
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Cover : Yes
Attachments : Cover.png
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 9 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 8 232 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.373
Stream size : 9.72 GiB (84%)
Title : hungdaita @ TayTO
Writing library : x264 core 142 r2431+42 c69a006 tMod [8-bit@all X86_64]
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=16.1500 / qcomp=0.60 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.20 / pb_ratio=1.20 / aq=1:0.75 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0 / zones=0,1420,crf=15/2171,2300,crf=15/2354,2398,crf=15/2432,2493,crf=15/2521,2533,crf=15/2557,2589,crf=15/2590,4025,crf=15/4119,4243,crf=15/9350,9457,crf=15/9570,9642,crf=15/9724,9942,crf=15/10052,10585,crf=15/10612,10839,crf=15/26554,26629,crf=15/27625,29207,crf=15/33093,35980,crf=15/52178,52270,crf=15/60823,60887,crf=15/62984,63072,crf=15/65119,65269,crf=15/65475,65745,crf=15/65791,65886,crf=15/65951,66059,crf=15/66180,66318,crf=15/78834,79911,crf=15/82015,82265,crf=15/82857,82985,crf=15/83346,83474,crf=15/85143,85255,crf=15/85480,85719,crf=15/85878,86018,crf=15/86095,86191,crf=15/86424,86551,crf=15/86616,86700,crf=16.5/86841,86893,crf=15/87015,87113,crf=15/87458,87556,crf=15/88211,88456,crf=15/88842,89377,crf=15/94040,94168,crf=15/94329,94490,crf=15/94575,94638,crf=15/97771,97869,crf=15/97918,98070,crf=15/100751,100815,crf=15/103055,103217,crf=15/12822,129099,crf=15/179497,179664,crf=15/183267,183384,crf=15/184696,185029,crf=15/194071,194223,crf=15/201105,203201,crf=15/235848,243210,crf=19
Language : English
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.78 GiB (15%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 42 min
Bit rate : 56 b/s
Count of elements : 2000
Stream size : 66.9 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 58 b/s
Count of elements : 2096
Stream size : 70.1 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 79 b/s
Count of elements : 1528
Stream size : 94.8 KiB (0%)
Language : Arabic
Default : No
Forced : No
Text #4
Format : UTF-8
Duration : 2 h 44 min
Bit rate : 87 b/s
Count of elements : 1630
Stream size : 105 KiB (0%)
Language : Bulgarian
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 54 b/s
Count of elements : 1954
Stream size : 65.2 KiB (0%)
Language : Danish
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 54 b/s
Count of elements : 1593
Stream size : 64.5 KiB (0%)
Language : Dutch
Default : No
Forced : No
Text #7
Format : UTF-8
Duration : 2 h 43 min
Bit rate : 51 b/s
Count of elements : 1536
Stream size : 61.7 KiB (0%)
Language : Finnish
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 63 b/s
Count of elements : 1778
Stream size : 75.3 KiB (0%)
Language : French
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 62 b/s
Count of elements : 1995
Stream size : 74.4 KiB (0%)
Language : German
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 111 b/s
Count of elements : 2363
Stream size : 133 KiB (0%)
Language : Greek
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 51 b/s
Count of elements : 1703
Stream size : 61.6 KiB (0%)
Language : Norwegian
Default : No
Forced : No
Text #12
Format : UTF-8
Bit rate : 51 b/s
Count of elements : 1663
Language : Polish
Default : No
Forced : No
Text #13
Format : UTF-8
Bit rate : 54 b/s
Count of elements : 1985
Stream size : 65.0 KiB (0%)
Language : Spanish
Default : No
Forced : No
Text #14
Format : UTF-8
Bit rate : 53 b/s
Count of elements : 1683
Stream size : 64.0 KiB (0%)
Language : Swedish
Default : No
Forced : No
Text #15
Format : UTF-8
Bit rate : 76 b/s
Count of elements : 2082
Stream size : 90.8 KiB (0%)
Language : Vietnamese
Default : No
Forced : No
Is there any particular instruction I have to click on the setup to keep the original screen ratios?
			Closed Thread
				Results 1 to 11 of 11
  PAL DVD - Progressive video but telecined frames during shaking sequencesBy GlitchBob in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2021, 19:06
  World FIRST 12K Blackmagic Camera Ursa Mini Pro IMAX LOOK (actually cheap!)By joejonas in forum Latest Video NewsReplies: 9Last Post: 21st Jul 2020, 09:25
  converting videos problemsBy xantiagreen in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2018, 17:08
  Poor picture quality during fast sequencesBy Mike2112 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 6th Aug 2018, 04:38
  Solar eclipse converting AVCHD to image sequences...By jeff d in forum Video ConversionReplies: 7Last Post: 28th Aug 2017, 21:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
