i'm new here and i just ripped my dvd to a vcd, but its not as clear as the dvd copy. is that how its supposed to be? i'm using dvd2avi, smartripper, and tmpgenc. I have a couple of dvd screeners on a vcd and the quality of that is like a dvd. Is there any way i can rip a dvd to vcd and make it look as clear as a dvd? thanks
Opinions on the subject may vary but you are probably never going to get the same visual quality on a VCD as a DVD. I DVD has 720 x 480 frame sizes where a VCD is 352 x 240. However, you can always encode in an XVCD format which gives you higher resolution capability in an MPEG1 format but your stand alone player (if that's what you want to play it on) may not play it. You could also encode it so SVCD which is an MPEG2 format and has a 480 x 480 resolution and is obviously closer to a DVD. It really depends on how many CD-Rs you want to put the movie on to and what your DVD player is capable of playing. By making an XVCD (i.e. a higher bit rate VCD) you can get much better visual quality in a VCD format but you will limit what you can put on a single CD-R. The same thing applies to the SVCD format.
I hope that helps.
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
