Hi ,
I don't know what I am doing wrong , I have created bd25gb iso images with menu using DVDFab and today I got a Blu-ray burner with 25 pack of Mediarange BD-R 25gb.
I have burned the first image using ImgBurn , the verification was 100% successful , the disc does play on my PC with VLC player but when trying to play it on my PS3 or ps4 the disc appears as BD-R it opens but the screen stays black.
I have no idea what is wrong or what should I have done differently.
It's my first attempt to burn some bd .
Any help would be highly appreciated.
Thank you.
Thank you! I will try to burn it with that settings , also I would like to ask , my iso images only have folders :BDMV , Certificate there is no DCopy file is that a problem?
Also would like to ask you if I have to set the region of the disc? I am in UK region B not sure if that's important . -
A minute is nothing for blu-ray menus to appear,dvd menus are worse.
Can't say that is always the case... My Star Wars Blu-Rays take a good 3-4 minutes to get to the screen and then you can't skip the animations so it is more like 5 minutes to start poking around and then the transitions take time etc etc etc.
Because the media had less space I felt DVDs didn't faff around as much.
In either case, if the disc was not full of extras I often made a "move only" disc that made the movie start once the disc was inserted. The menus added no value...
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 19:04 -
No sound on Blu Ray after burning
By Loplop in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Nov 2020, 12:25 -
Fastest encoding/burning time for Blu-ray software?
By Kal-El in forum Authoring (Blu-ray)Replies: 6Last Post: 20th Aug 2020, 16:46 -
Best free Blu-ray burning software?
By Master Tape in forum Authoring (Blu-ray)Replies: 9Last Post: 27th May 2018, 21:15 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32
