Results 1 to 22 of 22
    May 2006
    Canada
    Hi. I'm attempring to download the video on this page, but it fails whatever I do with either Internet Download Manager and Youtube-dl (even with the m3u8 file). TubeDigger can't even detect it at all. Everytime I try, it's an error message like this:
    Beginning download, this box will output progress
    Youtube-DL has been found and set
    Generating output directory structure
    The output was generated and will be used
    The quality and format has been set
    Looking for ffmpeg
    ffmpeg was found
    Arguments have been generated and are readonly in the textbox
    Creating download thread
    Created, starting download thread
    [generic] maedchen_im_frack_12_08_2021.1926.film.lang_sv.sub _en.mp4: Requesting header
    [generic] maedchen_im_frack_12_08_2021.1926.film.lang_sv.sub _en.mp4: Downloading m3u8 information
    [download] Destination: s.culturebase.org\Video\maedchen_im_frack_12_08_20 21.1926.film.lang_sv.sub_en.mp4-maedchen_im_frack_12_08_2021.1926.film.lang_sv.sub _en.mp4.mp4
    Error:
    ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
    Error:
    built with gcc 10.2.1 (GCC) 20200726
    Error:
    configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf
    Error:
    libavutil 56. 51.100 / 56. 51.100
    Error:
    libavcodec 58. 91.100 / 58. 91.100
    Error:
    libavformat 58. 45.100 / 58. 45.100
    Error:
    libavdevice 58. 10.100 / 58. 10.100
    Error:
    libavfilter 7. 85.100 / 7. 85.100
    Error:
    libswscale 5. 7.100 / 5. 7.100
    Error:
    libswresample 3. 7.100 / 3. 7.100
    Error:
    libpostproc 55. 7.100 / 55. 7.100
    Error:
    [https @ 0000021e3de7f640] HTTP error 403 Forbidden
    Error:
    https://s.culturebase.org/m/a/e/d/c/maedchen_im_frack_12_08_2021.1926.film.lang_sv.sub...p4/index.m3u8: Server returned 403 Forbidden (access denied)
    Error:
    ERROR: ffmpeg exited with code 1
    An error occured
    THIS IS A YOUTUBE-DL ERROR, NOT A ERROR WITH THIS PROGRAM!
    Any way to get around this please ?
  2. Originally Posted by monks19 View Post
    Can record using "Rec Mode" and embedded Chromium3 browser.
    May 2006
    Canada
    I tried that already. For some reasons TubeDigger doesn't seem do detect the links at all. Maybe something's wrong with the settings ? Have you been able to make it work ? If so, How ? Can you share the settings so I can try again ? I'll try to re-install it, see it it works.
    May 2006
    Canada
    Hi. I think I've finally manage to do it. However, the bandwith is so choppy that pixelisations does appear in the final video. Any way to go around that with TubeDigger ? Also, I saw that the video on the page was quite spead up. Is that normal ? also, could the spead cause this ?
    Thanks to let me know.
    PS To everyone: I'm also open to other methods, if available. Don't hesitate to let me know.
  5. Originally Posted by monks19 View Post
    It looks CDN of this video is slow at this moment.
  6. Originally Posted by monks19 View Post
    Yes, trying to record in x6 fast forward speed. Perhaps should add in future versions speed selector.
    May 2006
    Canada
    CDN ? Any way to get around this for a smooth recording ?
    Also, The only links the program gets (aside for the recording) only says "failed" if I try to download them. Any way that this can be arranged for the future ?
    May 2006
    Canada
    Yeah. And even if I try to play back, it's still bugging/buffering at the same place(s).
  9. flash_video_downloader_youtube_hd_download_4k-15.0.19-an+fx.xpi
    May 2006
    Canada
    Sorry. I'm not sure I understand. Can you explain/eleaborate on this, please ? I know that flash video downloader is no longer supported by firefox and can't be found anywhere at all, unless I'm wrong. Any other way ?
    Thank you
    May 2006
    Canada
    Any way to stabilyze the buffering while keeping the 720p resolution so the video stream can remain smooth while recording ?
  12. Code:
    yt-dlp https://transfer.sh/get/162hica/index.m3u8
    https://gofile.io/d/hRSMeM
    discord=notaghost9997
    May 2006
    Canada
    Hi. Thanks a lot. How did you manage to get it ? I'm asking becauses there are other videos like this one coming soon the next few days on this website and I would like to get them too.
    Thanks to let me know (please).
  14. Originally Posted by monks19 View Post
    He downloaded the m3u8 and edited to add "?t=1628961397&sig=PZkJNSpVXpKez-VngdXZQA" after every ts, then uploaded the edited m3u8 on transfer.sh
  15. Originally Posted by [ss]vegeta View Post
    would be easier if you do it with streamlink
  16. Originally Posted by notaghost View Post
    I'm trying for half an hour and I couldn't do it. Even with --http-query-parameter... that stupid & makes all problems, I think.
    I even tried escaping the character ^, tried double quoting, couldn't make it work.
    I even tried on Linux and couldn't!
    May 2006
    Canada
    Ok, sorry, but I'm totally lost here. Is it possible to explain the whole process ? I should add, for some reasons, my PC (with windows 10 64x) doesn't allow me the use of YT-dl directly with the CMD for some reasons. I have to use, normally as a work around, Video DownloadHelper in order to get a download link and then pass it through either Youtube DLG or a youtube-dl-gui. Otherwise, I'm completely lost. This time sadly, the usual process didn't work.
    Sorry if I'm asking you this @notaghost and @[ss]vegeta, but thanks if you can help
  18. Code:
    streamlink --http-query-param t=1628965483 --http-query-param sig=FeEE2MtQbUF442ck0_0blQ "https://s.culturebase.org/m/a/e/d/c/maedchen_im_frack_12_08_2021.1926.film.lang_sv.sub_en.mp4_240.mp4/index.m3u8?t=1628965483&sig=FeEE2MtQbUF442ck0_0blQ" best -o output.ts
  19. Originally Posted by notaghost View Post
    Argh!
    I thought of this!
    Really!
    ... but I didn't try it.
    I just thought "there's no way they will append like that", but... I guess they did!
    Nice, thank you!
    Don't open cmd from Start.
    Just open the folder where yt-dl is, and type "cmd" up there in the address bar/location.
  20. Sorry. I'm not sure I understand.
    waterfox 2020.10 (64-bit)
    https://github.com/attawjy/Firefox-old-addons-collection
    https://embed.culturebase.org/LZY5QHKAR8XE
    http://usb.iphoto.md/i2GLt
    May 2006
    Canada
    Can't install it. It says the file is corrupted. Although, I have the most recent Firefox version. That may be a factor why it doesn't work. Do you know which version is compatible ?
    Nevermind. Found the answer. Will report back after work.
  22. Member
    May 2006
    Canada
    Hi. It worked. Thanks for your help. My only regret is that I can't use Internet Download Manager to speed up the download time. Oh well...
    Again Thanks
