they have uploaded all of the events on their site. so far youtube-dl or streamlink not working with it.
https://olympics.com/tokyo-2020/en/replay/
Results 1 to 11 of 11
streamlink --http-header "User-Agent=xxx" --http-header "Referer=https://olympics.com/" --http-query-param "hdnts=xxx" "master_1.m3u8" best -o video.ts
[Attachment 60302 - Click to enlarge]
You can find the value of "hdnts" query string in the developer tools, by clicking on "master.m3u8" and scrolling down -
is hdnts value everything after 'hdnts=' also what should i put in User-Agent=xxx??
Yes.
Check the master m3u8 file on the network tab of developer tools for it.
You can also use an extension like The Stream Detector so it can generate the streamlink command for you. -
Usually Streamlink shows you the available streams (only video) if you don't add "best -o output.ts" at the end, but sometimes it throws an error (like in this case) and I really don't understand why.
Yes, you are correct.
Sorry, I couldn't reply before. I'm glad you have found the solution. -
FYI,the value is your IP address. (replace the XX with your actual IP when playback is done in browser)
Also master_1 is highest quality but video only, master_7_0.m3u8 is the one containing audio. You'll have to download them separately then merge with e.f. ffmpeg.Code:hdnts=ip=XX.XX.XXX.XX
nbcolympics.com / How to Download full Olympics Replays ?
By RajaBell in forum Video Streaming DownloadingReplies: 19Last Post: 4th Oct 2022, 14:25 -
Please please please, need help downloading NBC Olympics replays
By RajaBell in forum Newbie / General discussionsReplies: 0Last Post: 8th Aug 2021, 01:39 -
NBC Olympics Download Help
By narltv2 in forum MacReplies: 3Last Post: 29th Jul 2021, 11:45 -
10bit BT.2020 HDR content to 10Bit BT.2020 WITHOUT HDR metadata
By wmplib in forum Video ConversionReplies: 3Last Post: 10th Apr 2020, 07:44 -
CBC Olympics Stream
By olympusmons in forum Video Streaming DownloadingReplies: 2Last Post: 18th Aug 2016, 22:41
