  1. Assume I got a *mp4 video file originally captured by a smartphone.
    How can I now (later) find out if the video was taken in 720p or in 1080p mode?
    Does 720p ALWAYS have a resolution of 1280x720
    and
    does 1080p ALWAYS have a resolution of 1920x1080
  2. Anonymous
    Guest
    use mediainfo, it will tell you what you want to know
  3. Or open in VLC and look at codec info.
    May 2005
    Australia-PAL Land
    and
    Nobody's answered yet so here's my two-bob's worth.
    Yes, normally. My understanding is that there is only one "standard" resolution for, say, 720P, which is 1280x720. There is no "normal" 1440x720P. Your phone would only take "standard" resolution video eg 1280x720, 1920x1080.
    The second number denotes the "name" of the resolution eg 720, 1080. The P or I denotes whether the file is Progressive or Interlaced.
    However, your video editor may well be able to create any resolution. For example, for Facebook, you could make a video that was 1000x1000P.
    Mar 2008
    There is ambiguity in the question. Is the OP implying that
    the video was altered from the original capture? Too little context.
