  1. I have been trying to upload a video for over an hour now, and it is stuck at 0%. My internet is working, and I have uploaded another video successfully, which leads me to believe there is an issue with the video I am trying to upload. From what I can tell, the video complies with YouTube's recommended encoding settings, but I must be missing something, so I've listed the MediaInfo below hoping someone can help me figure out what's wrong. Thanks in advance for any help!
    HTML Code:
       General
        Format profile                           : Base Media
        Codec ID                                 : isom (isom/iso2/avc1/mp41)
        File size                                : 6.21 GiB
        Duration                                 : 27 min 7 s
        Overall bit rate                         : 32.8 Mb/s
        Writing application                      : Lavf58.42.102
        Video
        Format profile                           : Baseline@L4
        Format settings                          : 1 Ref Frames
        Format settings, CABAC                   : No
        Format settings, Reference frames        : 1 frame
        Format settings, GOP                     : M=1, N=12
        Codec ID                                 : avc1
        Codec ID/Info                            : Advanced Video Coding
        Duration                                 : 27 min 6 s
        Duration_LastFrame                       : -33 ms
        Bit rate                                 : 32.4 Mb/s
        Width                                    : 1 920 pixels
        Height                                   : 1 080 pixels
        Frame rate mode                          : Constant
        Frame rate                               : 29.970 (30000/1001) FPS
        Bits/(Pixel*Frame)                       : 0.521
        Stream size                              : 6.13 GiB (99%)
        Writing library                          : x264 core 157 r2970 5493be8
        Encoding settings                        : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=12 / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc=crf / mbtree=0 / crf=15.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=0
        Color range                              : Limited
        Matrix coefficients                      : BT.709
        Codec configuration box                  : avcC
        Audio
        Format                                   : AAC LC
        Format/Info                              : Advanced Audio Codec Low Complexity
        Codec ID                                 : mp4a-40-2
        Bit rate mode                            : Constant
        Bit rate                                 : 374 kb/s
        Channel layout                           : L R
        Sampling rate                            : 44.1 kHz
        Frame rate                               : 43.066 FPS (1024 SPF)
        Stream size                              : 72.5 MiB (1%)
        Default                                  : Yes
        Alternate group                          : 1
    Feb 2006
    try deleting the file and try again.
  3. Tried that and unfortunately it did the same thing when I went to upload it again.
  4. 6GB for 27 minutes only? re-encode video and try again.
    (maybe too big for youtube?)
  5. 6GB for 27 minutes? yikes.
    May 2005
    Australia-PAL Land
    If your file is that big/high quality, you should make it 2560x1440 so that YT will encode it in VC9 format. VC9 gives better quality. The 1440 is the dimension that kicks in the VC9 codec.
    From a recent thread on Videohelp.
    You can see YT videos that have been encoded with VC9: right-click on the video and choose "stats for nerds".
    Read the update for this YT video:
    https://www.youtube.com/watch?v=2v7FH_pQ-lQ
