I have a .sub (microDVD) file converted to .ssa and I need to put a permanent sub on the avi file. I used the howto at the left but when I use the subtitler filter the subtitles are not syncrinized with the video file (aout 5 sec delay). What can I do?
Wschindel
Reasonably simple
Open your ssa subtitle file using Sub Station Alpha
Under the menu item Timing, there s a function called 'Shift timing'
Input the proper offset for your subtitles (you may have to do a bit of trial and error here), save the file and off you go.
Cheers
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 13:05 -
virtualdub - > problem with subtitles
By alibaba12 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2012, 17:58 -
Subtitles not showing up in VirtualDub
By vaskimies in forum Video ConversionReplies: 2Last Post: 18th Jun 2011, 13:29 -
Hardcoding subtitles with VirtualDub
By sypolts in forum Newbie / General discussionsReplies: 5Last Post: 3rd May 2010, 06:44 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
