i have Adobe Premiere 6, and i would like to cut my avi file, like the beginning of a movie so the size would be a little bit smaller. I would like to keep the quality, and just cutting some part of the movie off. Is there any website or tutorial that can answer my question.
please help
Download VirualDub (find some older versions as well and create subfolders in the virtual directory so you can have a few versions on your PC at once) Then drag your movie file into the VD (VirtualDub) application and then using the little time bar at the bottom, drag it to the start of where you wanna cut it and hit 'HOME' then move it along to the end of where you wanna cut it and hit 'END'. It'll say somein like 'offset end ...l' and then just hit delete... Once your done cutting ect.. Select [File/Save AVI] then give it a name and it'll save the video as AVI.
That was brief but hope it helps... :sThis is that block of text which gets added to all the posts I create. There is a 255 character limit. -
P.S - If you spesifically wanted to cut it in Adobe, then 1. its going to be a little mission 2. whats wrong with VD, its free and easy...???
Im wierd!This is that block of text which gets added to all the posts I create. There is a 255 character limit. -
...not forgetting to select *Direct Stream copy* before saving!
fps: 640x272, 23.976
# frame 90550 (1:02:56)
decompressor: DivX 5.0.1 Codec
# of keyframea: 927
audio rate: 48000 Hz
channel: 2 stereo
smaple precision: 0-bit
compressor: Fraunhofer IIS MPEG Layer-3 Codec
MY AVI, WHEN I TRY TO CUT SOME PART IN THE MIDDLE OF THE MOVIE, IT doesn't cut it when i export it. -
Hi,
I need you guys' expertise. I have the following problems:
1. There's nothing wrong with VD, but my AVI files are from DV, so they are DV compressed...the VD does not support that.
2. I really need a AVI software which can cut and merge AVI files (DV compressed AVI files).
3. I also need a good DV capture softare. Could anybody recommend one?
Currently I am using Adobe Premiere 6. But you need to manually check { .. } and log In/Out.... It's kind waste of time.
Then I found another software called scenalyzer , which can create video index of the whole DV tape in 5 minutes. But the problem of this software is that it tries to be too "smart"....and it didn't provide the function to let user "manually" choose the place we want to capture. Instead, it makes you several "scenes", which is sometimes not the place we really want.
Your help will be much appreciated.
Thank you. -
I'm still not certain why Vdub won't work. It loads in DivX avis which are compressed.
As to DV capturing I would check out the other forum. -
odyssius98
I capture DV with Scenalyzer then trim and edit with Premiere. It's hard to beat Premiere for editing DV. Then frameserve the DV to TMPGenc for producing an mpeg.
As for the original question, I don't believe that Premiere supports DIVx. If it did, you have to make sure that your source files and output file settings are the same.
Virtual Dub is a much better tool for the original problem.
AVI Videos Cutting Out
By Blade of Tyshalle in forum Newbie / General discussionsReplies: 11Last Post: 8th Feb 2012, 13:49 -
Cutting Ripped AVI
By quxote in forum EditingReplies: 4Last Post: 24th Feb 2008, 14:47 -
cutting a few frames from an avi
By tommid in forum Newbie / General discussionsReplies: 7Last Post: 17th Oct 2007, 19:52 -
Cutting avi's with APE 3?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 13:35 -
Cutting AVI without all the re-encoding
By gameroftheuk in forum EditingReplies: 6Last Post: 31st Aug 2007, 23:13
