Hi guys I have my 4k collection and I have ripping some movies that I like to see on my hard disc but this take a lot of space, I notice on some sites there are rippings in 2160p 265 in maybe 7gb and the qualityi is amazing, so I so wish to do that with my collection but I don´t know the tool to use and some guide step by step?
And this movies says 10bit I dont know what it means or what is the difference?
If you just could helping me how to do it?
Thank you in advance!!
Results 1 to 10 of 10
Check google for 10bit video vs 8bit video.
I would try Vidcoder. There are a range of presets you can experiment with to find the best compromise between size and quality for your needs.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Just encode the video with a lower bit rate and see if you like the results,do a minute encode so you can have samples without running a full encode.
Batch convert H.265 MKVs to H.264
By Nico Darko in forum Video ConversionReplies: 2Last Post: 28th Jun 2020, 18:09 -
Cannot edit 2160p files
By SirDarknight in forum EditingReplies: 1Last Post: 18th Mar 2018, 08:26 -
2160p resolution lags
By Luzkan in forum Software PlayingReplies: 0Last Post: 17th Jan 2018, 19:12 -
Should I convert videos to H.265?
By yuppicide0138 in forum Video ConversionReplies: 8Last Post: 29th Nov 2017, 04:50 -
how to convert h.265 mkv into h.264
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2017, 14:48
