Is it possible to remove the numerous dupe frames from a choppy 25fps Zoom video download, convert to 23.976, and keep the running time the same?
I've been experimenting with Hybrid, but I can't seem to find the best settings.
If you remove "numerous" duplicates , this means the output must be variable frame rate (VFR) to keep the same running time and to keep sync. ie. each frame will have different display durations, some longer, to compensate . VFR does not improve the "choppiness" - it will appear exactly the same in terms of bad motion
The only way to improve the choppiness is to interpolate synthesize new in-between frames, such as with optical flow . Some issues with this approach are generated artifacts, and for "numerous" duplicates - strings of more than 2 - it can be difficult to "automatically" determine which frames to interpolate. It depends what you mean by "numerous" - are they groups of duplicates, strings of triplicates or more? .. etc... -
sRestore(frate=23.976) should be able to do that.Is it possible to remove the numerous dupe frames from a choppy 25fps Zoom video download, convert to 23.976, and keep the running time the same?
After that, I agree with poisondeathray, frame interpolation is probably your best (automated) change.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
MediaInfo tells me the file is 25fps, contant frame rate, progressive.
I'm seeing no more than one or two dupe frames at a time.
I've tried a few different settings with sRestore and Interpolation in Hybrid, but the output files still have dupe frames. I guess I'm not setting the various other options correctly? -
Might be can't really say without a sample. Might be that you have to use a lower frame rate with sRestore to first remove all the dupes, but depending on the source going to low might not be a good idea if it means losing to many good frames.
how to download a video broadcast from the site zoom.us?
By SenVik in forum Video Streaming DownloadingReplies: 5Last Post: 15th Feb 2021, 10:14 -
Software to zoom every 10 seconds to a video
By kirwix in forum Video ConversionReplies: 3Last Post: 8th Dec 2020, 16:34 -
Zoom in effect of video in the background, in a video slightly in advance a
By HiLem in forum EditingReplies: 1Last Post: 30th Jul 2018, 20:20 -
Video capture software for zoom meeting
By p75213 in forum Video Streaming DownloadingReplies: 1Last Post: 19th Jun 2018, 22:56 -
How to Zoom into a part of my Video.
By rookkeeper in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2016, 11:44
