Hi.
i am a newbie to the forum so a quick hello to all members and please go genital on me.![]()
i was wondering if Anyone would happen to Know What DVD Player Is being Used In This Rare DVD Player that i own? also would there happen to be a multi-region hack for it.
thanks so much in advance guys. any help would be so much appreciated.![]()
here is some photos of the Player.
[Attachment 60217 - Click to enlarge]
[Attachment 60218 - Click to enlarge]
[Attachment 60219 - Click to enlarge]
[Attachment 60220 - Click to enlarge]
[Attachment 60221 - Click to enlarge]
[Attachment 60222 - Click to enlarge]
[Attachment 60223 - Click to enlarge]
[Attachment 60224 - Click to enlarge]
[Attachment 60225 - Click to enlarge]
Results 1 to 10 of 10
lol. take it apart and see what drive is in it if you want. it's not like it's likely to be anything but the cheapest drive available at the time.
I think (hope?) you meant genial or gentle, not genital.
Regardless, aedipuss is correct, a special consumer tie-in item like that is going to have the bottom of the barrel internals, as that is not the prime selling point of the piece. You can also tell by looking at the cheesy knock-off remote.
While it would be possible to gut it and replace with a decent player (possibly from a former mobile/portable disc player), it might not be possible without doing some damage to the ouside face (might not even be possible with the same model without special tools).
My suggestion is to leave it as it is (whether to keep or sell). And use a standard player for your disc-playing needs.
Scott -
+1 to both posts.
Any value (which is probably minimal as with most collectibles of this type) is in the case, not the internals. Anything to do will lower the value more than the <$50 you'd spend on a regular DVD player.
Edit: Looking it up, it's super craptastic because video is only composite out. Another indicator of super cheap internals.Last edited by lingyi; 7th Aug 2021 at 23:19.
the drive probably is a crap cheap drive. i can imagine because of the country wear it was made. i would love to through that drive out and put something in more reliable. but you can pay up to $100 for these players as there were only a limited number of them made.
https://www.ebay.co.uk/itm/324025167908?hash=item4b7167b024:g:Rq0AAOSwhaFg09iL -
Changing the drive doesn't change the fact that it's only composite out. It's not the drive that's the real issue, it's the video output.
Also, your link shows that it's ~$1000, not $100 and I've seen others asking $400-$500. It's your choice to ruin a collectors item just to get nearly the worse possible video output (RF out is worse) just for the novelty of using something that never was intended to be practically used. -
thanks lingyi
yes you are right. i think it is best just to be left as a collectors novelty item.
and yes i meant to say $1000 i mist a 0
Well I, personally, would not give this house room
Not so sure about the earlier comment of this not intended for practical use.
https://www.youtube.com/watch?v=jnnS-HJ2qv4&t=309s -
To complement your collectable player, I suggest https://www.amazon.com/Hamburger-Shape-Storage-Case-Bag-24-disc/dp/B0055X0W6Y
Sincotec 8150 dvd player and Alba 70S dvd player Reverse Slow Motion?
By vinckles in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2020, 06:52 -
Built-in VHS player in CRTs, image quality vs external player?
By xAlienxx in forum MediaReplies: 4Last Post: 7th Mar 2019, 18:57 -
youtube player versus perfect player
By lafamar in forum Video Streaming DownloadingReplies: 5Last Post: 19th Aug 2018, 12:42 -
Sony BDPS6700 4K Upscaling Blu-Ray Disc Player/Make Multi Region Player
By swu1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2017, 16:05 -
[GOM Player] How can I make GOM Player open every video with same defaults
By czerwinski76 in forum Newbie / General discussionsReplies: 0Last Post: 5th Feb 2017, 12:52
