Results 1 to 15 of 15
  1. Banned
    Mar 2017
    Hi! In some most music videoclips there ones are high-pitched audio but synchronous with video. I also tried with ffmpeg but to no avail. Is there any freeware software that allows you to increase the audio pitch with the video, since this option does not exist for ffmpeg? I'm searching everywhere. Thank you.
  2. Is the pitch too high or too low?
  3. Banned
    Mar 2017
    High pitch.
  4. Use clever ffmpeg-GUI.
    Load your file, click main, click audio conversion, set the audiostream you want lower the pitch, click continue, set the audio codec you want, in the coefficient box enter 0.800000, set pitch only, click convert.
    If the pitch is ok for you, mux the new created audio with the video.
    If not, change the coefficient value.
  5. Banned
    Mar 2017
    This program doesn't work it! Here it is:
    "Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
    sono riportate in fondo al messaggio.
    ************** Testo dell'eccezione **************
    System.ComponentModel.Win32Exception (0x80004005): Impossibile trovare il file specificato
    in System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
    in clever_FFmpeg_GUI.Module1.ShowVideoTracks()
    in clever_FFmpeg_GUI.Form2.Show_Tracks()
    in clever_FFmpeg_GUI.Form2.Button2_Click(Object sender, EventArgs e)
    in System.Windows.Forms.Control.OnClick(EventArgs e)
    in System.Windows.Forms.Button.OnClick(EventArgs e)
    in System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    in System.Windows.Forms.Control.WndProc(Message& m)
    in System.Windows.Forms.ButtonBase.WndProc(Message& m)
    in System.Windows.Forms.Button.WndProc(Message& m)
    in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assembly caricati **************
    mscorlib
    Versione assembly: 4.0.0.0
    Versione Win32: 4.8.4300.0 built by: NET48REL1LAST_C
    Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    clever FFmpeg GUI
    Versione assembly: 1.0.0.0
    Versione Win32: 2.8.2
    Base di codice: file:///C:/Users/Antonio/Downloads/x64/clever%20FFmpeg%20GUI.exe
    Microsoft.VisualBasic
    Versione assembly: 10.0.0.0
    Versione Win32: 14.8.4084.0 built by: NET48REL1
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Versione Win32: 4.8.4270.0 built by: NET48REL1LAST_C
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Versione Win32: 4.8.4084.0 built by: NET48REL1
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Versione Win32: 4.8.4190.0 built by: NET48REL1LAST_B
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Windows.Forms.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
    mscorlib.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
    ************** Debug JIT **************
    Per abilitare il debug JIT, è necessario impostare il valore
    jitDebugging nella sezione system.windows.forms del file di configurazione
    dell'applicazione o del computer (machine.config).
    L'applicazione inoltre deve essere compilata con il debug
    abilitato.
    Ad esempio:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    Quando il debug JIT è abilitato, tutte le eccezioni non gestite
    vengono inviate al debugger JIT registrato nel computer,
    anziché essere gestite da questa finestra di dialogo."
  6. Hai fatto il download di ffmpeg.exe, ffplay.exe e ffprobe.exe?
    Hai seguito tutti i passi iniziali del programma?
    Esegui:
    In case of startup errors or problems, delete this folder (it will be created again automatically):
    C:\Users\xxx\AppData\Local\clever_FFmpeg_GUI (where xxx=your user name on windows).
  7. Banned
    Mar 2017
    Now it works! Thanks! I downloaded ffmpeg,ffprobe and ffplay. But I have difficulty to use the video/audio pitch conversion. This program not make for me!
  8. No video conversion needed, only audio conversion. Read the info above.
  9. Banned
    Mar 2017
    Where's "pitch only" setting?
    [Attachment 60213 - Click to enlarge]
  10. Originally Posted by VHGNM View Post
    Under the coefficient box.
  11. Banned
    Mar 2017
    It doesn't exist! Where's "pitch only"? Are you kidding me?
    [Attachment 60214 - Click to enlarge]
  12. Write 25 into the source fps box and 22 into the target fps box. Then change coefficient to 0.80000
  13. Banned
    Mar 2017
    Sorry! I haven't notice this option. Thanks!
  14. @ VHGNM
    I just noticed that the Pitch only option was only included in a developer version. I have now put this online as the latest beta version. If you still need it, you can try it.
  15. Banned
    Mar 2017
    I've found a best solution to increase video/audio speed with 3 free softwares to high pitch with audio/video sync.
    For video I've using QWinFF to increase video speed: I've added a video from QWinFF and then Next in "Add work" dialog I've clicking on Edit and in "Time" setting on Speed I've set 104%. And then I convert. But in QWinFF I can't pitched it who then I've found another great solution for audio...
    For audio I've used Audacity with FFMPEG settings to convert MP4 to MP3 and set Speed to change pitch and increase speed of audio as 4,00. Then I saved as MP3. And now it's coming a marvellous...
    To set audio and video pitched as the same speed,I've using Video to Video Converter,on a setting called "Audio/Video Mux" to set Video and Audio mux. I've set an MP4 video and MP3 audio,then I convert as Direct Stream Copy and done. That's the very real solution to set speed video/audio clip. Instead of FFMPEG,Free Speed Video,Clever FFMPEG-Gui,Avidemux,VirtualDub and another video editors/converters who hasn't a best setting to set a specific video/audio speed,that's are the best free softwares to create these ones. That's all folks! I fixed it! Thank you very much!
