I've recently discovered that homebrew app on my nintendo wii has one media playing feature, that can play both PAL and NTSC dvds from all regions. Now the real question is: does it worth it? Is wiis analogue output any good
No.
Read this for the different options for Wii output: https://www.reddit.com/r/WiiHacks/comments/gzfzbn/the_complete_guide_to_wii_video_output/
Bottom line, use it for what it's intended for as even a $20 DVD Player with HDMI will give you better picture quality. -
A mod is the only way to play NTSC dvds on a PAL wii, and vice versa. The output is comparable to a standard dvd player. I never noticed any difference between a wii vs my admittedly cheap dvd player using component outputs.
Multi-region DVD players are <$50 and many cheap non-name brand players are region-free and will play both NTSC and PAL DVDs out of the box because they're made to be sold in multiple markets worldwide. If they don't work out of the box, they can often be hacked to make them region-free. https://www.videohelp.com/dvdhacks. But be aware that many of the hacks are old and may not work on newer players with the same model number.
If you can hook up your computer or laptop to your TV and your DVD drive isn't region locked (usually not with current drives), you can use your software media player which is TV system agnostic.
Bottom line, much better quality options than the Wii. -
I guess I was still living in the past in which computer drives are region locked. Thanks!If you can hook up your computer or laptop to your TV and your DVD drive isn't region locked (usually not with current drives)
Drives are classified as RPC-1 (region changeable) or RPC-2 (region locked). All current drives are RPC-2 and have been for more years than I can remember.
However Region Codes are controlled by software which is why official players such as PowerDVD exist to change the Region (limited to 5 times per drive and then you require another program to clear that setting) or programs such as DVDFab Passkey which effectively makes the drive Region Free.
However software players such as vlc ignore Region Codes and will play any dvd.
Multi-format VCR player with good comb filter
By TheRealOC in forum Newbie / General discussionsReplies: 16Last Post: 7th Dec 2020, 23:03 -
Nintendo Wi U or Nintendo Switch
By Tom Saurus in forum Off topicReplies: 10Last Post: 5th Oct 2020, 04:33 -
Sony BDPS6700 4K Upscaling Blu-Ray Disc Player/Make Multi Region Player
By swu1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2017, 15:05 -
Good DVD player that will also play multi formats from USB drive.
By nicksteel in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2016, 20:53 -
Reset Regional Code for Philips CED750 DVD player
By Eddie Wentzel in forum Newbie / General discussionsReplies: 7Last Post: 9th Sep 2016, 13:13
