Hello,
I've been trying to download the following video: https://www.cbc.ca/i/caffeine/syndicate/?mediaId=1921271363853
You can also find it on: https://www.cbc.ca/player/sports/olympics/sport%20climbing (The titled "Climbing - Women's Prelims")
I've tried several methods but none seem to be working as nothing is recognizing that there is a video in the links. I also saw a previous thread about using youtube-dl but for whatever reason running the .exe only launched cmd for a second and then it disappears and the command is unknown if I try inputting it normally on a fresh cmd.
Any help is greatly appreciated!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
The whatever reason is that youtube-dl is a command line tool, meaning you can't just run the exe and work with it. Although there are command line tools that can work when you run the exe normally, youtube-dl isn't that kind.
If the command is unknown when you try inputting it normally, it means you run cmd from a different folder than the one where youtube-dl is.
This is fixable by adding youtube-dl to enviroment path, but for you it's probably better to just run cmd from inside the folder of youtube-dl.
So
put youtube-dl in a folder of your choice
then in the address bar just type cmd
it will open cmd in that folder and you can use youtube-dl from that cmd.
Use the command LZAA mentioned, and you also need a ffmpeg.exe in that folder, you can download that from here
https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-full.7z -
@jomjomeh You could make a new text file in youtube-dl folder and write in it
@echo off
youtube-dl
pause
between @echo off and pause add the commands you want and change the extension of the text file from txt to bat, then run the batch file, and you will need ffmpeg.exe in the same folder with youtube-dl.exe as mentioned before. -
It helps youtue-dl with a lot of things like merging video and audio streams and stuff.
I think the command will download the best quality.
However, if you want to see all the available qualities you should just add -F in the command, that should be written right before the url.
That will list all the available qualities. Streams should have different names/format codes.
Then you can use lower case -f to select streams for downloading.
If video and audio are separate, then you'll have to use -f "format code of video"+"format code of audio".
Newbie needing advice - History lesson
By FatHaz in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2021, 08:30 -
needing help with a video file issue
By Ryan in forum Newbie / General discussionsReplies: 7Last Post: 30th Apr 2020, 10:58 -
Newbe needing help deciding best way to convert minidv Hi8 and HD video tap
By peterellen in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2020, 09:24 -
Pgs or sup to srt without needing the ocr
By fits79 in forum Blu-ray RippingReplies: 8Last Post: 25th Aug 2018, 15:05 -
Needing help please for VideoLan downloads on W10
By motdaugrnds in forum ComputerReplies: 2Last Post: 17th Mar 2018, 11:41
