Results 1 to 20 of 20
  1. I can't crack using YDL, youtube-dl or other downloaders I just don't know how to do this and have been trying for over 6 hours.
    I have SlingTV with all the add-on packages and can easily watch every event on the NBC Olympics website, but when it comes to downloading it I am useless, I would really appreciate anyone walking or showing me how to download one of these event replays in the highest possible quality available.
    an example of the video I am trying to download
    https://stream.nbcolympics.com/track-and-field-session-8-integrated-feed
    [Attachment 60170 - Click to enlarge]
    I just don't know how to use YDL or youtube-dl now that I have that url above, It's hard to find a tutorial on what to do next, but It would mean the world to me if someone can just spend 5 mins to show me what to do
  2. Send login info (user/pass) via private message so I can access and I'll show you .
    Jan 2021
    Argentina
    Try with Streamlink
    streamlink --http-header "User-Agent=Your User Agent" --http-header "Referer=https://stream.nbcolympics.com/" --http-query-param "hdnts=See Screenshot" ".m3u8 link" best -o video.ts
    [Attachment 60233 - Click to enlarge]
  4. Originally Posted by lfer94 View Post
    Try with Streamlink
    So I need to Paste that command above into Streamlink ?
    How do I use Streamlink ?
    Jan 2021
    Argentina
    Yes
    Download and install it like any other software. Then go to any folder, press shift + right click, click "Open PowerShell window here", paste the command and press "Enter"
  6. Originally Posted by lfer94 View Post
    Yes
    Okay so got streamlink, got my VPN and also got CMD open ready, how do I enter this video link to download it ?
    https://stream.nbcolympics.com/track-and-field-session-10-mens-triple-jump-qualifying
    Would you be able to write me out the command to enter into CMD to get that video above please ?
    I will give you my SlingTV details if needed (SlingTV is any other TV Provider is needed to be able to watch through the NBCOlympics Website)
    Jan 2021
    Argentina
    Press F12 before playing the video to open Developers Tools, then click on Network panel, type "m3u8" into the filter imput box (as shown on the screenshot above), and copy the first "master_vod.m3u8" link.
    I could do it, but you would get an error. You must do it by yourself.
    Just copy this in notepad and replace what's in red with what you find in the developer tools
    streamlink --http-header "User-Agent=xxx" --http-header "Referer=https://stream.nbcolympics.com/" --http-query-param "hdnts=xxx" ".m3u8 link" best -o video.ts
    That's what you must to copy and paste in notepad (where it corresponds)
    [Attachment 60234 - Click to enlarge]
    Jan 2021
    Argentina
    It should look like this:
    streamlink --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36" --http-header "Referer=https://www.directvsports.com/" --http-query-param "hdnts=exp=1628413746~acl=*~hmac=d9a9d189767b09be1078665a4627473a9a04d7064c2d08aafc369a9d2d86532e" "https://directvsports-live.akamaized.net/hls/live/2026679/DTVSPAN/stream05/hdntl=exp=1628500092~acl=%2f*~data=hdntl~hmac=e9d89268f0f5644fbd9d5e7db242dc43ecbcf565c93c0d735e7d29082f6e1532/streamPlaylist-archive.m3u8?startTime=1628096100&endTime=1628103600" best -o video.ts
  9. Originally Posted by lfer94 View Post
    Appreciate the help a lot
    Jan 2021
    Argentina
    Restored
    PS: The help I gave you above was more than enough to you be able to download those videos
  11. lfer94 Thanks for your post, this is great. But I'm having a problem. Maybe you can help me?
    I tried your method, and on some videos it works and some others it doesnt. I'll explain.
    I watch the replays on nbcolympics without logging in (no cable service). Watching this way give me a 30 minute time limit to watch a video. Then I have to empty browser cache and restart the browser to watch another 30 minutes. The video RajaBell posted is like this. Has 30 minute limit. But for example this video has no time limit.
    The one that has no time limit also has no hdnts parameters and I can download it just fine. However any video that has hdnts info and I enter it as you explained doesnt work. I get the "forbidden" error from streamlink.
    Could you give it a try again and see of its working for you? because it sure isn't working for me.
    I found another way to download these expiring videos but I run into another problem. The solution I found is to use the address of VIDEO_0_6569000_vod.m3u8 file which looks like this:
    https://sprtlive28.akamaized.net/hls/live/586446/NBCOlympics0c1a4751/clear-1/exp=16323...96000_vod.m3u8
    And to use the syntax of:
    streamlink "above URL" best -o xxx.ts
    This is able to fetch the video and starts downloading. However to download most videos takes more than half an hour and the server might cut me off.
    So do you have any solution?
    If I could restart downloading from the middle of the video then it would help. But I don't know how. This way I could download the first half, and then start a second stream and download the second half by dictating a start time. Is there such a parameter?
    Would appreciate your help man.
  12. Ok, I was reading the documentation on streamlink and found this parameter:
    https://streamlink.github.io/cli.html
    --hls-start-offset [HH:]MM:SS
    Amount of time to skip from the beginning of the stream. For live streams, this is a negative offset from the end of the stream (rewind).
    Default is: 00:00:00.
    I'm about to tinker with it see if I can get that to work. Not sure abut the syntax, whether I should write as "00:00:00" or "[00:]00:00". But gonna test and see.
    I also wonder if its possible to simply add parameters at the end of the m3u8 url and get the server to simply send the right data. Maybe you guys can shine some light on that. I don't know the syntax to try it.
    ***EDIT: Ok I tested with "00:00:00" format and its working! I can start from an offset. So I've solved my problem. Sorry to trouble you guys and thanks for this forum and your support.
    Jan 2021
    Argentina
    I can't play the video that Raja Bell posted, so I can't test it. If you post here all the request headers for any video with hdnts info, maybe I could help you.
    You can increase the download speed adding --stream-segment-threads 10
    streamlink --stream-segment-threads 10 "URL" best -o xxx.ts
    Yes. This will start the download after the first 30 minutes.
    streamlink --stream-segment-threads 10 --hls-start-offset 00:30:00 "URL" best -o xxx.ts
    You also can set the duration adding --hls-duration 00:00:00
    streamlink --stream-segment-threads 10 --hls-start-offset 00:30:00 --hls-duration 00:30:00 "URL" best -o xxx.ts
    I never tested it so I'm not sure if it would work.
  14. Hey thanks lfer. Much appreciated
    Thanks mate, but its not necessary. Its working quite ok now. Actually better than I thought possible.
  15. What do you do if there's no hdnts? Sorry, but I'm all new to this and trying to figure things out. I'm been trying to dl. this vid from Olympics.com: https://olympics.com/en/video/women-s-pole-vault-qualifying-b-athletics-tokyo-2020-replays.
  16. Originally Posted by fosman View Post
    Use The Stream Detector add-on.
    It gave me this, which seems to start downloading just fine
    ytdlp -N 8 --no-part --restrict-filenames --user-agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36" --referer "https://olympics.com/" "https://vod-b.olympicchannel.com/output/tok1000991/manifest-1655228268.m3u8?hdnts=exp=1664830517~acl=/*~hmac=c29317e5187b31c0902abf574d8fe1f66284b18e0d8a9666fc92d57ea7eefbac"
    [generic] *~hmac=c29317e5187b31c0902abf574d8fe1f66284b18e0d8a9666fc92d57ea7eefbac: Downloading webpage
    [generic] *~hmac=c29317e5187b31c0902abf574d8fe1f66284b18e0d8a9666fc92d57ea7eefbac: Downloading m3u8 information
    [info] *~hmac=c29317e5187b31c0902abf574d8fe1f66284b18e0d8a9666fc92d57ea7eefbac: Downloading 1 format(s): 6312+audio_group-ENGLISH
    [hlsnative] Downloading m3u8 manifest
    [hlsnative] Total fragments: 1879
    [download] Destination: manifest-1655228268-[~hmac=c29317e5187b31c0902abf574d8fe1f66284b18e0d8a9666fc92d57ea7eefbac].f6312.mp4
    WARNING: The download speed shown is only of one thread. This is a known issue and patches are welcome
    [download]   7.9% of ~5.36GiB at    1.32MiB/s ETA 02:35 (frag 149/1879)
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  17. yt-dlp have built in extractor for olympics.com
    so, use simply yt-dlp https://olympics.com/en/video/women-s-pole-vault-qualifying-b-athletics-tokyo-2020-replays
    to download at best res available (or add -F to see all resolution available)
