Hello
any help for download
https://stream.nbcolympics.com/nbc-primetime-july-25
Results 1 to 12 of 12
Need a VPN for USA, use StreamlinkCode:
streamlink "https://sprtlive5.akamaized.net/hls/live/586261/NBCOlympics663eddfd/clear-1/exp=1628126842~acl=%2fhls%2flive%2f586261*~data=hdntl~hmac=daee1648777e94fc139d951e0779dadab75c674614184c26df10c7090c2ff6b6/VIDEO_1_4596000_vod.m3u8" best -o xxx.ts
i download the softwer for streamlink ,, but where i put the link for download ?
The posted link might not work and you need to get a fresh one.
Open developer tools in Chrome.
That's done by right click -> inspect and open the network tab (before you start the video).
Start the video and you should find the link that will be something like this
Copy it and replace it in the command posted up there.Code:https://sprtlive5.akamaized.net/hls/live/586261/NBCOlympics663eddfd/clear-1/exp=1628126842~acl=%2fhls%2flive%2f586261*~data=hdntl~hmac=daee1648777e94fc139d951e0779dadab75c674614184c26df10c7090c2ff6b6/VIDEO_1_4596000_vod.m3u8
Now copy the whole command.
Open any folder where you want the video.
Type "cmd" up there in the address bar of windows explorer.
And paste in the black window. -
i have got the link ... but after copy it like these
streamlink "https://sprtlive5.akamaized.net/hls/live/586261/NBCOlympics663eddfd/clear-1/exp=1628530994~acl=%2fhls%2flive%2f586261*~data=hd ntl~hmac=33bee88809d9628c31fca8244dbd466b64232e87b 17e52541336dd5314f10d84/1627250958_video_720p-30fps-4500k/video_529.ts" best -o xxx.ts
and past it on command i have got
C:\Users\lenovo>streamlink "https://sprtlive5.akamaized.net/hls/live/586261/NBCO
ac=33bee88809d9628c31fca8244dbd466b64232e87b17e525 41336dd5314f10d84/1627250958_v
error: No plugin can handle URL: https://sprtlive5.akamaized.net/hls/live/586261
tl~hmac=33bee88809d9628c31fca8244dbd466b64232e87b1 7e52541336dd5314f10d84/1627250
958_video_720p-30fps-4500k/video_529.ts -
Hmm, that's weird.
Did you properly install Streamlink?
Maybe you had an older installation of Streamlink and you didn't know?
Maybe you downloaded just an .exe and didn't install it?
If I remember correctly when I installed Streamlink, everything was default. And it works on my end.
Do you have a a folder like this?
[Attachment 60238 - Click to enlarge] -
Erm, I don't see any master_vod.m3u8 in your link.
You've grabbed a wrong link from the network.
Your link points to a single segment
video_529.ts
and next time don't dot me like "I have got the link..." -
In the same folder from where you started the cmd and used Streamlink command.
I already explained you, you are not reading.
From the command u posted, looks like you started cmd from the start menu, so it opens (in your case) in
C:\Users\Lenovo
Help NBC Subtitles CC
By Lucas V in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2020, 12:41 -
Download stream for Olympic Figure Skating event? No access soon.
By nobodyhome in forum Video Streaming DownloadingReplies: 5Last Post: 25th Feb 2018, 16:44 -
download from nbc olympic
By supersport in forum Video Streaming DownloadingReplies: 0Last Post: 25th Feb 2018, 09:10 -
NBC stream changes
By 44897681 in forum Video Streaming DownloadingReplies: 7Last Post: 4th Nov 2017, 15:22 -
How to upload Olympic videos to youtube ?
By kwanami in forum Video Streaming DownloadingReplies: 1Last Post: 27th Aug 2016, 06:33
