  1. I cannot play burnt VCD's on my computer ever since I upgraded to XP. I have searched the web for an answer but all I found was people with the same problem. The Mpeg file(before burning) plays fine. And of coarse the VCD plays great on my stand alone DVD player. I used to be able to play them when I had Windows ME.
    Help!!!!!
    May 2002
    Rio de Janeiro, RJ
    :x
    I'm having the exact same problem... I was able to play VCDs fine in Win98 SE, but when I upgraded to XP it's impossible... I tried about 10 players... all of them hang.
    I can't even copy the .dat file to my harddrive... it gives me a "cyclic redundancy check" error...
    I'll try and find something... if u find, will you let me know?
    thanks
  3. i can a get a vcd to play perfectly i dont know what are you talking about i have xp too.
    May 2002
    Rio de Janeiro, RJ
    I just found out it's a problem with my CD-ROM-RW (a LG model: GCE-8240B) drive... I went to the page and downloaded its documentation... it says there it can only play VCDs with a separate interface card... weird hun?
    I already contacted them about it... and I'm waiting for a reply.
    Regards
