ok, i've been ripping dvd's for a LONG time, so it's hard for me to change what i do.i've always ripped in this order:
SmartRipper -> DVD2AVI -> TMPGEnc
i'm pretty sure i can't get subtitles this way, and i've never needed to, but now with some things i'm getting into, i need the subtitles. what would anyone else suggest for usage of subtitles AND good quality?
EDIT: in looking everything over, i think DVD2AVI is the reason the subtitles can't be done in my method. am i correct?
You just need to add one step to your process.
SMartripper ==>DVD2AVI==>Virtual dub==>TMPGEnc
Please note:
As virtual Dub cannot read the file created by DVD2AVI, you'll have to convert this file. The program is called: VFAPi conv. you can find it on the download section of this side.
In Virtual Dub you'll have to add the Vobsub filter.
The exact steps are:
1 Smartripper
2 DVD2AVi
3 VFAPIconv
4 Virtual dub with the Vobsub filter. Then FRAMESERVE to
5 TMPGEnc
The quality if subs is very good.
A good guide how to do this; http://www.flexion.org
If you are creating SVCD, then i might be a good idea to check the possibilities of DVD2SVCDThe Dutchman -
that site isn't working right nowOriginally Posted by xzarkad
for the method (vobsub/vdub) that xzarkad is talking about check this out:
http://www.doom9.org/vobsub.htm
another good method to add subs is flaskmpeg/avisynth:
http://www.vcdhelp.com/dvdtovcdflask.htm
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
