Hello;
I have got around 100 .m4a audio files having DTS 768kbps but i cant play them in my led tv bcoz it doesnt support it.
So i want to convert them to 5.1ch 640kbps ac3.
MeGui only allows to process single file at a time so it will take a lot of time to do so.
Any way/software to batch process all files at once?
hi, there are 2 possible solutions,
[1] convert [dts] .m4a → ac3 "losing quality"
[2] change container [dts] .m4a → [dts] .mka "without loss of quality"
using "XMEDIA RECODE"
I had a similar problem, and it worked for me, just changing container m4a → mka
but it depends on your tv,
You could try the method [2] and if it doesn't work, then [1]
[for the test choose only one file]
XMR → Method [2] "m4a → mka"
1.add audio to XMR
2. "format" tab
-format = MATROSKA AUDIO
3. "audio" tab
-mode = copy
4.add to queue
5.encode
If the MKA file plays on tv, then you would just have to convert all the audios.
1.add all audios
2. keyboard shortcut → "CTRL + A"
and continue steps from "2."
XMR → Method [1] "m4a → ac3"
1.add all audios
3. "format" tab
-format = AC3
4. "audio" tab
-mode = convert
-channels = 5.1
-bitrate = 768
4.add to queue
5.encode -
Thank you so much, it will definitely solve my problem.
BTW first one option will not work for me bcoz i want to downgrade 768kbps to 640kbps or below as DTS is not supported by my LED TV.
So i just converted it to .mka ac3 codec and changed bitrate to 640kbps, havnt tried in TV yet but im sure will solve the problem.
Thanks again. -
I also use the FFMPEG solution, but if you don't like command lines look at the post I just did about downloading YouTube videos.
Any Video Converter has a GUI and will convert audio as well as video.
https://www.any-video-converter.com/products/for_video_free/ -
1.add all audios
3. "format" tab
-format = AC3
4. "audio" tab
-mode = convert
-channels = 5.1
-bitrate = 768
4.add to queue
5.encode
責任者-MDX
batch convert DTS to Ac3 using ffmpeg
By Mishari in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2022, 16:23 -
Best way to get AC3 640kbps directly to Blue Ray / DVD
By linkadge in forum Authoring (Blu-ray)Replies: 5Last Post: 5th Mar 2021, 11:44 -
batch Mkvmerge to select only the AC3 audio and ignore any AAC audio
By olpdog in forum EditingReplies: 3Last Post: 11th Aug 2019, 04:00 -
folder batch convert eac3 to .m4a @128
By skylinekiller in forum AudioReplies: 12Last Post: 13th Jun 2018, 14:24 -
Aegisub - batch support? or better way to batch process/edit subtitles?
By Restricted in forum SubtitleReplies: 7Last Post: 5th Sep 2017, 22:10
