I just made a VCD and everything during the process went perfectly. Went to pop it into my home DVD player and the DVD player didnt like it. I looked in the CD I made and there are a bunch of folders and odd files that I dont recognize on there. Should there be a *.vcd file on there? I have a large file sized *.dat file, but nothing that specifies a VCD. I'm wondering if there was a burning mishap, or maybe my DVD player can't play VCDs? It is an older one, so I'm wondering if thats it.
Any help is appreciated.
if the dat file is in the mpegav file that good...
have you tried burning on a cd-rw? they are often more compatible
did you check out the dvd player list? it might give you soe hints as to why it doesn't work -
I have no idea but did it work in your computer???
This will bump you anyhow. I am sorry I have no answer. -
Thanks guys; and yes, the dat file is in the mpegav folder. I'll try again with a CDRW, but I'm begining to think thats its my DVD player. I'll check the list of compatibility. thanks!
Burned in subtitles help
By aftermay in forum Newbie / General discussionsReplies: 18Last Post: 30th Mar 2013, 13:24 -
Burned in timecode - HOW?
By synaptic in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2009, 23:41 -
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 21:41 -
burned subtitles
By ckoshikumo in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2008, 22:32 -
want to play burned cd in my car
By terrie29 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2007, 01:55
