  1. I'm currently using HandBrake to compress my home videos with the AVC x264 library. However, I recently saw a video that was compressed using the HEVC x265 library and was very impressed with the compression and quality.
    I opened the HEVC video in MediaInfo and this was the data it showed:
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L3.1@Main
    Codec ID : V_MPEGH/ISO/HEVC
    Duration : 1 h 50 min
    Bit rate : 1 117 kb/s
    Width : 1 280 pixels
    Height : 544 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Variable
    Frame rate : 23.976 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.067
    Stream size : 879 MiB (90%)
    Writing library : x265 3.1.2+1-76650bab70f9:[Linux][GCC 8.3.0][64 bit] 10bit
    Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1280x544 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=0 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=1133 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
    Language : English
    Default : Yes
    Forced : No
    How can I enter those settings in the HandBrake UI to compress my videos with the same efficiency? I'm looking to compress my videos with the same settings as the ones listed above.
    Thanks for your help.
    Mar 2008
    This appears to be the SLOW preset, with ref=4 specified (default 3).
    The encode set MAIN10 profile, level Auto
    Bitrate control specified ABR at a rate of 1133 (probably single pass)
  3. That makes sense, since encoding at slower speeds leads to better compression, but how did you get that ref=4 means the slow encode setting? Is there a conversion guide?
    Mar 2008
    Not really, I just had some stats saved for some of the presets, I found the one that looks the closest.
    ABR at single pass not advised, 2-pass much better
  5. Wrote something 6 years ago to convert MediaInfo 'Encoding settings' to x265 command line: Mis265 there are probably some changes since then, but it might help to get started.
    Cu Selur
