Results 1 to 30 of 33
  1. Hi looking for tool to find key for protected video, anyone can help me with this, willing to pay for your attention
    Regards
  2. psaframe
    Mar 2021
    Algeria
    Just a advice, It's very saturated, you'll end up getting scammed.
    Most of the content is already available.
  3. Originally Posted by Yamiraan View Post
    Regards
    Has anyone been in touch? I am also searching
  4. https://github.com/Satsuoni/widevine-l3-guesser/
    Inviato dal mio SM-G970F utilizzando Tapatalk
    Discord Sei#0555
  5. this method is working on my side, if anyone need more details can msg me and i will help happily
    Thanks @pedrothelion
    Apr 2021
    Dominican Republic
    Thank you very much, if it works, it takes a little longer but it is still effective.
  7. Originally Posted by Newbiect View Post
    It depends on the CPU... say about 10 minutes.
    There's an offline version implementation here
    A configuration file will be downloaded automatically i.e. offline_config.json, just copy it to the wvguesser directory.
    Still needs a browser apparently for exporting config json only (about a secs) then can work offline but still takes time.
    There's a chance for directly drag offline_config.json to wvguesser_v1.1.0.exe. Here the exe builded.
    This method seems a little faster (+30%).
    Apr 2021
    Dominican Republic
    Ok I'll try it, thank you very much.
  9. Originally Posted by pedrothelion View Post
    Nope.
  10. Originally Posted by [ss]vegeta View Post
    Nope.
    Did you try?
    I've tested py only.
  11. Originally Posted by pedrothelion View Post
    Did you try?
    What you mean you tested "py" only?
    I tried 1.1.0 and it was barely 5% faster.
  12. Originally Posted by [ss]vegeta View Post
    Did you try?
    I mean loading wvgueeser folder.
    Anyway here's how exe works:
    Jan 2021
    Argentina
    Thank you very much for sharing, it worked for me. But do you by any chance know if it is possible to download the config.json file manually? Because the WVGuesser extension doesn't work with videos of FB Watch.
  14. Originally Posted by lfer94 View Post
    Because the WVGuesser extension doesn't work with videos of FB Watch, for example.
    FB watch is drm protected?
    discord=notaghost9997
    Jan 2021
    Argentina
    Yes, there are some live streams (ussually sporting events) that are drm protected. Like Copa Libertadores matches, for example.
  16. Originally Posted by lfer94 View Post
    Use non offline version:
    Discord Sei#0555
    Jan 2021
    Argentina
    Of course! I hadn't thought of that because when I first tried it, it took so long that I thought it wasn't working 😅.
    I'll try again hoping it works. Thanks!
    Edit: Well it doesn't work, but it was not really important so there's no problem.
  18. the offline version does not work for me, if I start the .exe (1.4.0) and play the video on the website, it does not downloaded the config.json automaticlly as it is written in the readme.
    is there any other steps to do ?
  19. First unzip the plugin and load it Chrome, in developer mode.
    Play the video.
    offline_config.json will download.
    Drag .json in .exe
    160s to obtain a key with a ryzen 3900x
  20. Originally Posted by krazykenny View Post
    Delete Chrome plugin and reinstall again folder and put this exe into the same wvguesser folder
  21. Originally Posted by lfer94 View Post
    Can you share a link to FB watch video with Widevine?
  22. Originally Posted by cntnes View Post
    Play the video.
    Drag .json in .exe
    ah thx, I did not read that the plugin is a chrome extension !
    now it works
    i7 9700k @4,5GHZ: [Progress] 100% time used 126.15s3s
    Notebook with AMD Ryzen 5 3500U: [Progress] 100% time used 361.91s4s
  23. A big update. With the last version get the keys is instant now.
    Discord Sei#0555
  24. Member
    Jan 2021
    Argentina
    Sure https://fb.watch/75fWBikChN/
    You probably need a vpn for Argentina or Brazil
  25. Member
    Jan 2021
    Argentina
    Finally! Goodbye to waiting almost an hour (!) to get just one key. Thank you again .
  26. Originally Posted by lfer94 View Post
    not protected for me?
    audio: https://video-gru1-1.xx.fbcdn.net/v/t42.1790-29/10000000_181802047305212_8922258220450540887_n.mp4?_nc_cat=101&ccb=1-3&_nc_sid=5aebc0&efg=eyJ2ZW5jb2RlX3RhZyI6ImRhc2hfbGl2ZV9tZF9mcmFnXzJfYXVkaW8ifQ%3D%3D&_nc_eui2=AeHmoLI_wCu3w2gPUkVAbJDjj9R0E49a066P1HQTj1rTrhLW_vZxzELsO9X7T2f3I5L1VUD9adm3hIKP_6g_NFfH&_nc_ohc=Ax0zNMndPtEAX_slfMl&_nc_ht=video-gru1-1.xx&oh=a61b008f4018d8349512e49695401db6&oe=6105B5F5
    video : https://video-gru2-2.xx.fbcdn.net/v/t42.1790-29/10000000_2918095488449529_7537189637217132381_n.mp4?_nc_cat=111&ccb=1-3&_nc_sid=5aebc0&efg=eyJ2ZW5jb2RlX3RhZyI6ImRhc2hfbGl2ZV9oZDFfZnJhZ18yX3ZpZGVvIn0%3D&_nc_eui2=AeEQMhyyNC5w3-Yl-ITo83zaBmOYC64y-UEGY5gLrjL5QTmSCVkTjF4k7dpP0obH-hVk27EcXza5Ec7lRaAQOSag&_nc_ohc=z-npPAOAGXQAX8oSl1y&_nc_ht=video-gru2-2.xx&oh=061bada1c993f674b8a1a6e39f0b7d83&oe=6105BC9B
  27. Originally Posted by cntnes View Post
    Play the video.
    Drag .json in .exe
    I've done the first steps. I have played the video. Where can I find "offline_config.json"? Thanks
  28. Member
    Jan 2021
    Argentina
    You are right, it's not protected . And it's strange because they usually are, like this one.
    I don't know what could have happened, but I hope it was on purpose and not by mistake.
    PD: The latest version of Satsuoni's extension worked on videos of fb watch
  29. Member
    Feb 2006
    click on the link and change www to mbasic (mobile version of facebook)
    hit enter and then try playing the video. you should be able to right click on the video and click save as
    to download the video.
  30. Originally Posted by dzigelbaum View Post
    when you play video, after 1 sec offline_config.json is downloaded by your browser.
    if you don't get this file, probably you don't have drag&drop WVGuesser-plugin.zip into browser extension window
    (you need to enable developer mode for this)
