I'm trying to play a Doctor Who Blu-ray in VLC. It's from the classic series, so it's original 576i50 video that's meant to have the smooth "live video" look, upscaled to 1080i50.
Normally, I'd just turn on deinterlacing in VLC and set the deinterlace type to "Bob". This works perfectly for DVDs - I get the correct video motion, with the 50i video bobbed to 50p.
But this isn't working with Blu-ray. The video still looks filmised. Is there something different about the way Blu-ray handles interlaced video compared to DVD?
MediaInfo tells me that the source video stream from the Blu-ray is 25fps, top field first. That's the same info I'd get from a DVD. So why doesn't VLC bob-deinterlace Blu-ray video the same as DVD?
I've even tried ripping an episode with MakeMKV and throwing it into Handbrake, set to bob-decomb to 50fps - and I just get horrible juddery video output. So there's definitely something weird going on.
Of course, if I play the disc in a standalone Blu-ray player, it all looks correct - I get the fluid "live video" motion.
Can anybody point me in the right direction?
Results 1 to 12 of 12
If it's the original series, the analog video was 405 lines/50Hz so it would already be upscaled to 576i50. Possibly the interlacing isn't line by line any longer.
Brian. -
The original series was only 405 lines until 1967, when it switched to 625-line monochrome (and then 625 colour in 1970). None of the 405-line stories exist in their native form anyway, they're all 16mm film recordings (kinescopes).
I can throw the ripped video into ffWorks (a macOS front end for ffmpeg) and bob-deinterlace it to 50fps successfully. So no idea why VLC and Handbrake don't want to do it. -
Could the problem be vlc itself ? It is not a fully-functional blu-ray player. Have you tried software that is such as PowerDVD Ultra or DVDFab Player ? Even these, I guess, could choke if the actual issue is the up-scaling.
BTW (Out of curiousity) You said 'Classic' Doctor. Can you be more specific ? (Not a great fan. I only have the early William Hartnell dvd box set plus 'A Christmas Carol' since Katherine Jenkins was in it
I'm probably off the planet right now but if I read correctly there is some confusion in the BD terminology. There is no such thing as 1920*1080i50 (= frames). These 'frames' are actually fields and the correct description is 1920*1080i25
Source:
http://www.hughsnews.ca/faqs/authoritative-blu-ray-disc-bd-faq/4-physical-logical-and-...ifications#4.5
(I probably watched Tom Baker back in the day. Got a little silly after that - apart from Katherine Jenkins
Could this be the key to the issue ? -
Don't know how to properly deinterlace and clean SD video
By memo90061 in forum RestorationReplies: 3Last Post: 1st Jul 2020, 17:23 -
VLC on new computer...still no Blu-Ray support?
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2020, 03:33 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 02:11 -
Playing blu-ray discs on VLC? (What am I doing wrong?)
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 28th Dec 2018, 05:35 -
is there any way to make vlc play blu ray iso files?
By MyMaMa in forum Software PlayingReplies: 5Last Post: 4th Dec 2017, 07:35
