(VirtualDub2, saving as mp4 x264 aac) How to exactly use it? I would have to convert about 500 smaller files with same settings, without having to open up one by one 500 times, but have no clue how to use this wizard once the needed files are opened inside it. Is it even possible, can anyone help out?
Ok I've found that under the Job control/File is something called Process directory. But after I load the directory to Job control and click start, on every file I get an instant Error status (and I've set the desired copression parameters earlier). What gives?
If you're unable to get it to work in vdub try this instead
https://www.videohelp.com/software/Pazera-Free-MP4-Video-Converter -
From Virtualdub's main screen .
F4/File/Process directory/Select source directory
Find the input folder and click 'Select Folder'
Find the target folder and click 'Select Folder' (This happens immediately after selecting the Source folder.)
Source and target folders cannot be the same folder if the target file names are to be the same as the source.
If you crash and burn - From the main screen - View/Log (F8)
CheersLast edited by pcspeak; 26th Jul 2021 at 17:42.
Can anyone tell me how to do batch resize settings in Virtualdub?
By Guernsey in forum EditingReplies: 12Last Post: 7th Jan 2019, 04:35 -
VirtualDub -> Batch saving image sequence won't work properly
By killeriguana in forum EditingReplies: 8Last Post: 24th Sep 2018, 13:48 -
Batch conversion using Virtualdub batcher
By Trq in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2018, 05:45 -
using virtualdub to batch process deshaking, saving using h264 codec
By seanincali in forum EditingReplies: 7Last Post: 31st Mar 2017, 12:38 -
Virtualdub Batch Question
By thecoreyburton in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2017, 23:25
