Hi there, was hoping that somebody might know a solution to my problemSo originally I had a retail 3D bluray that I shrinked down to fit a 25GB disk by using BD-rebuilder. This 25GB copy ended up being a so called in-mux 3d bluray (which means the left and right eye videos spliced together into one m2ts file, without using the ssif folder structure).
The problem occurs when I use DVDFab to convert this 25GB in-mux 3d bluray to a HSBS (Half-SBS) 3d mkv file. The resulting output 3d mkv file has a problem with the 3d video. The synch/coordination between the left and right video is just plain wrong and loses all depth and pop-out effects. Has anyone encountered this problem before and know how to solve it? Just to mention, if I use the retail 3D bluray (with ssif) to convert to HSBS using DVDFab, then the output 3d file is looking fine.
Results 1 to 1 of 1
Converting MKV to MP4 Sync problem
By chang123 in forum Video ConversionReplies: 7Last Post: 7th Apr 2019, 19:41 -
Bluray Mkv to normal bluray disc
By Igniz in forum Video ConversionReplies: 3Last Post: 10th May 2017, 23:15 -
Mux many mkv files again without subtitles
By Ninelpienel in forum Video ConversionReplies: 11Last Post: 15th Jan 2017, 10:36 -
Mkv's batch srt mux
By euphonic in forum EditingReplies: 8Last Post: 2nd Nov 2016, 14:36 -
problem after problem converting Ts and MKV to mp4
By xtal_01 in forum Video ConversionReplies: 4Last Post: 3rd Oct 2016, 21:52
