How do burn bd-re disc in a computer that are recordable in a Panasonic blu ray recorder which I think supports avc hd, I have used Freemake video Converter to burn video to a bd-re which I was astounded plays perfectly but when I try to “copy” using the Panasonic menus the disc is not recognised, the Panasonic will copy from numerious created DVD’s -RW, DVD Ram, using various software but when I try blu ray it will not, the Panasonic will convey video to blu ray then burn to various blu ray blank discs which can be copied to the hard drive, My tv is not DNLA enabled and there are no USB ports I use the rgb connections as the way to transfer video which is not hd quality, As I am unable only to copy once to a computer generated bd-re I haveto use a different bd-re to achieve this it is a waste of a blu ray did , Has anyone had the same problem, I’d there a way round this,
Maybe the answer can be found by consulting your Blu-ray recorder's manual. If you want additional pairs of eyes to help you look, you'll need to post your Blu-ray recorder's model number so that the owners of those eyes can download a PDF copy of the manual.
KM Player latest version issue. How to solve the issue? Please help me
By jobsp90 in forum Software PlayingReplies: 0Last Post: 18th May 2020, 05:48 -
bluray disc from folder to iso And a picture in the virtual disc icon
By CapricornX10X in forum Blu-ray RippingReplies: 3Last Post: 27th Jan 2020, 13:01 -
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 14:44 -
Is this a tape issue or head issue?
By Vitality in forum RestorationReplies: 4Last Post: 8th Feb 2019, 20:28 -
Picture Weaving Issue (Stabilization Issue)
By nostalgia in forum RestorationReplies: 1Last Post: 31st Jul 2018, 05:23
