I'm currently using Handbrake's GUI queue to convert some video to x264 in serial fashion and would like to know if anyone has any tips on maximising GPU/CPU usage to reducing encoding time and/or a way to parallel process?
I've been using NVEnc in order to utilise my GPU for conversion, but it only ever seems to register about 10% video encoding usage. I also have an Intel HD 4600 GPU available that supports IntelQSV (currently doing nothing at all) and my i7-4790K shows maybe 20% utilisation. I generally have about 25GB of memory available.
I'd really like to make much better use of my available resources.
Keep in mind that encoding on a GPU is fast, but does not offer the best possible quality, compared to a good software-encode.
In handbrake, you could turn on igpu for decoding, it might give you a boost and max out your nevnc pipeline.
You could also try to decode on your nvidia gpu - one very easy way would be to use as-video converter - which gave me the best overall speeds without much configuration to be done when dealing with hardware-encoders and decoders, and also do simple and powerful batch encodes.
Staxrip and hybrid can also be configured to decode and encode on GPUs.
VSDC HW accelleration & GPU usage
By PerfectLiving in forum Video ConversionReplies: 0Last Post: 5th Jul 2021, 12:30 -
GPU or CPU encoding?
By m00511 in forum Newbie / General discussionsReplies: 44Last Post: 17th Nov 2019, 20:03 -
Potplayer + MadVR, GPU usage is halved when resized or fullscreen?
By Rumba47 in forum Software PlayingReplies: 0Last Post: 10th Jun 2018, 15:58 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 17:17 -
Issue with 4k/UHD Remux - playback looks poor quality + 0% GPU usage
By Deep Euphoria in forum Software PlayingReplies: 9Last Post: 25th Jan 2018, 17:02
