1st off I am an old fart at this game. I started fixing tv's, open reel recorders and so on while they still had vacuum tubes in them. I have fixed vcr's and windows based computers in the past. I had to retire from fixing things in 1995 due to micro tremors hands.
Anyways about 3 or 4 years ago I bought new in the box Funai model ZV427FX4 combo VHS/DVD recorder. On a regular bases I have cleaned the rollers, heads and so on in the machine with Q-tips and rubbing alcohol. The DVD side still works fine. But it has been a long time since I worked on the VHS side other then to clean the heads and rollers. Now when I put a VHS tape in. The tape goes in and starts to play for about 5 seconds then the machine shuts down. When I hit the power button the tape is ejected. I also tried covering the record tab on the test tape so the auto play won't kick in and tried rewind and fast forward. Both work for about 5 seconds then the power goes off, I turn the power back on and the tape gets ejected. I know there is a reason for this problem but I just can't remember the reason. My memory is not as good as it was. I had a stroke on 11-20-20. Amongst some of the things that I have lost is some short term memory and left peripheral vision. I think I can fix it or a young 19 year old that works with me in the electronics dept at the Veterans Warehouse Thrift Store, where I volunteer, he is studying to be an electrician. He is very quickly picking up on things like a VOM, an O-scope and both audio and RF Generators.
Steve-KC7BYP
	Hi....It's an eccentricity of the jvc (and perhaps different brands) menu screens and is typical conduct. The player doesn't separate Chroma/luma appropriately while yielding the menu through s-video out of the blue. However, it doesn't anily affect playback.
	Possibly the mode switch is stuck. It should be located below the tape.
  vhs tape will NOT move through vhs recorder at allBy tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31
  GPX DVR 9511 C DVD and VHS Player and Recorder - Region Code HackBy pooh in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd Apr 2020, 16:30
  Looking for VHS to DVD Recorder Combo with TBCBy JDinVT in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2019, 04:32
  Macrovision VHS to DVD recorder + RF problems with Panasonic recorderBy guy24s in forum DVD & Blu-ray RecordersReplies: 16Last Post: 29th Oct 2018, 06:43
  Need to hook up a DVD Recorder, VHS/DVD player, and a TV and can't get itBy Robbie R in forum DVD RippingReplies: 6Last Post: 22nd Feb 2017, 11:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
