A VHS conversion client wants a copy he can play in his Blu-Ray player in addition to the digital deliverables.
I've got all the tapes captured, processed and ready to rock at 704x480 interlaced, currently in MagicYUV 422. I also have some DVD-sourced MPeg2 and MiniDV-sourced AVIs.
In doing some reading of threads here, doom9, etc. from the past 10+ years, I'm not clear on what's today's best option for putting all this on a playable Blu-Ray. The dude says his machine has scoffed at some pro-burned stuff before, so I'm aiming for more compliance than dropping some video files on a BD-ROM, unless that itself is a reliable delivery method. I dunno. I've burned very few BR-R over the years.
My questions, if I may ...
- Is 704x480 legal for Blu-Ray? I've seen some yes, some no. If I have to pad things out, fine, bah, fine.
- I've seen some say Blu-Ray is OK with Mpeg2 files that are DVD compliant. I've seen others explaining that the Blu-Ray standard is full of sticking points that, if missed, break compliance.
- Mpeg2 or AVC? I see the "h264 sucks for interlaced" myth debunked in posts a decade old, so I'm torn.
- I'd love love love it if the solution has an easy GUI with a "make this Blu-Ray Okay!" button, but the "most likely candidate to work (but hasn't yet)" is x264.exe with a very long command line. Some middle ground?
- Recommended course of action? I have a crap-ton of tools to work with but have succumbed to paralysis by analysis.
Thank you, gang.
Oh, and the x264 command line that choked on the source was:
Code:x264 --bitrate 9000 --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --bff --colorprim "smpte170m" --transfer "smpte170m" --colormatrix "smpte170m" --sar 10:11 --pass 1 -o out.264 "kris-01-vhs-memories-raw-to encode"
Just read What Is Blu-Ray.
720x480 MPEG2 is okay, 704x480 is not. I'd suggest making one as a test and sending it to the client to test. -
You may want to import your videofiles in BD-Rebuilder and let it do the job. It will convert the files as neccessary and produce blu-ray compliant outputs, format and file structure-wise, including a basic menu if desired.
https://forum.doom9.org/showthread.php?t=143716
Be prepared for a certain learning curve though.
Edit:
If you want to proceed manually, here an overview of blu-ray compliant AVC (x264) video formats:
http://web.archive.org/web/20210620231325/https://forum.doom9.org/showthread.php?t=154533
Keep in mind that audio has to be compliant as well.Last edited by Sharc; 22nd Jul 2021 at 08:18.
Thanks, all, for the valuable feedback. The main article linked in "what is Blu-Ray" outlines a whole bunch of allowable sizes, 704x480 among them, but that was for a particular use case among all the different sorts of streams, so I bet you're correct.
After looking at the options, I went with old standby TMPGENC and its Authoring Works program. It read the MagicYUV AVIs just fine and did a painless job of transcoding. Faster than I expected, too, considering I'm making two discs of 20+GB. The menus are cheese, but as long as they work, I'm not going to complain.
Correct Filter Settings In Handbrake When Encoding 24fps NTSC for Blu ray
By the associate in forum Video ConversionReplies: 0Last Post: 17th Jan 2021, 08:34 -
Blu-ray compliant with ffmpeg 2-pass vs mp4
By Squeeto in forum Video ConversionReplies: 7Last Post: 14th Feb 2019, 22:04 -
Quick way to convert 720p 30FPS H.264 to Blu-Ray compliant video?
By 87th-E in forum Video ConversionReplies: 5Last Post: 18th Nov 2018, 12:28 -
Subtitle: .srt to .sup (blu ray format)
By kalemvar1 in forum SubtitleReplies: 4Last Post: 21st Mar 2017, 23:49 -
Play DV format in Blu ray player and TV.
By Kmroc in forum Video ConversionReplies: 14Last Post: 22nd Jan 2017, 11:21
