Yes i've tried Huffyuv, but i just havent got the disk space. Any suggestions?
, i hope to be able to convert to VCD.
well if you dont have the space u can always try nano dvr, winvcr
cyberlink something recorder
ravisent cineplayer dvr
etc....they all capture in mpeg, i gotta warn ya tho quality is bad
i odnt really know what iuvcr i so i cant help ya with the settings
but i depending on howq much space you have u can always try another codec,
sorry i couldnt really help ya further
perhaps clearifying your Q with your specs would help
in general its a good thing to always post your specs it helps people alot in giving you a usefull answer
good luck -
With computer specs basically identical to yours, when I use iuVCR, I capture to Picvideo's MJEG at a quality setting of 13-17 depending on the length of the capture and then I recompress it to another format (divx) for burning onto CDs.
I only have 7 gigs free on my harddrive and with the quality setting at 14/20 I can fit nearly three hours on it. The quality isn't lossless, but it's good enough for me and people often can't tell the difference between it and huffy or uncompressed when I show them clips.
There should be more than one MJEG codec available, but unfortunately, they're rarely free.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Settings Xvid codec in Virtualdub
By Docoptik in forum SubtitleReplies: 7Last Post: 6th Mar 2011, 14:15 -
How can I edit cedocida codec settings in windows 7?
By dssdss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Sep 2010, 02:10 -
XVid codec settings question?
By 3thman in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 16:36 -
Xvid Codec settings (1.2.2)
By glenpinn in forum Video ConversionReplies: 2Last Post: 21st Jun 2009, 10:29
