Am unable to keep capturing on a desired disk as Scenalyzer keeps reporting it to be full. Had to change the destination to a spare disk I wish not to use, and it all works on that other disk. But what to do with this let's call it primary disk I wish to keep using for this job? I have tried all I could think of to no avail. Formatted the disk 5 times, deleted all the instances of Scenalyzer from the registry 5 times, reinstalled the app 5 times... but it just keeps reporting 'could not use the disk it is full'. Any other ideas?
check your settings that show how much hard drive space to leave
Sorry I don't get you. The drive is an empty 4TB ssd. I have tried and can do whatever I want with it, write or copy onto it whatever from wherever. The only problem is with scenalyzer that won't capture to it.
there should be a setting in the Scenalyzer program that allows you to capture past a certain gig limit - https://forum.doom9.org/archive/index.php/t-29980.html
That setting is ok here. If that was the problem then it woudn't work all the same to this other disk, which is a 2TB M.2 SSD, and which is working fine. No, it is just this first 4TB SATA3 SSD which only Scenalyzer doesn't like, for whichever reason.
EDIT: Self solved kind of. Tried to split the 4TB GPT formatted SSD into two 2TB GPT partitions to see what happens and now it works. Not exactly what I had hoped for b4 purchasing the SSD but oh well.Last edited by kodec; 19th Jul 2021 at 19:57.
Scenalyzer Manual (PDF)
By Obtong in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2020, 22:37 -
Scenalyzer cliplist question
By jtech1 in forum Capturing and VCRReplies: 1Last Post: 14th Jan 2020, 08:18 -
How to start a new project in Scenalyzer?
By malling in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Sep 2019, 05:56 -
Scenalyzer Reports Wrong HDD Size and Operates Much Slower on New Computer
By Armandoban in forum Capturing and VCRReplies: 6Last Post: 23rd Mar 2018, 09:01 -
Scenalyzer problems.
By digicube in forum Capturing and VCRReplies: 1Last Post: 25th Feb 2017, 23:59
