  1. Hello
    I have create alot of SVCD movies in my time on earth. And i always hade DirectShow checked. But for a few days ago i did creat a vcd from a guide and in that guid it was standing that i should not use DirectShow. So i did uncheck it. Now i cant check it back. everytime i do it TMPGEnc will froze and not start so i have to open the ini file and select the value 0 to remove DirectShow. I think i need this checked wene i create Widescreen movies. Anyone that no what the prob is?
    THX
    USiT
  2. Go back and check direct show then move it up to the highest prioty. That should do the trick........
