Has anyone evaluated the Azure compute instance types for video processing and encoding? What would you recommend?
I am processing a large amount of video from old DVDs (with source material from the 80s) to h265 using ripbot264 (for degraining, sharpening, upscaling, color conversion).
What have you tried and can recommend?
I don't have access to the instances that have GPUs, so non-GPU based instance type recommendations would be greatly appreciated.
Results 1 to 1 of 1
Merge .srt & .mp4 without encoding video & audio?
By alexeliasson in forum SubtitleReplies: 9Last Post: 11th Jan 2021, 10:42 -
AviSynth+ fails on Azure
By miguelmorin in forum EditingReplies: 0Last Post: 17th May 2020, 17:11 -
Best Export Format/Ext. and Presets - Pinnacle in this instance
By BobbyL in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2019, 15:53 -
Azure Media Services Manifest
By jsvictor1989@gmail.com in forum Video Streaming DownloadingReplies: 0Last Post: 26th May 2017, 06:28 -
What's the best software to play all video file types?
By mikehende in forum Newbie / General discussionsReplies: 18Last Post: 24th Mar 2017, 11:04
