I have a set of 100 images and I would like to convert them into a video with crossfade between images.
I need each image to be shown for 5 seconds then to crossfade to the next.
Is it possible to do that in AviSynth?
I am using Windows 8.1
The images are in JPG format but I can convert them to PNG or other format if required
Not sure whether there isn't an easier solution, but something along the lines of:
should do the trick.Code:LoadPlugin("PATH TO ImageSeq.dll") # http://avisynth.nl/index.php/ImageSequence LoadPlugin("PATH TO GScript_26_32.dll") # http://avisynth.nl/index.php/GScript # "I need each image to be shown for 5 seconds then to crossfade to the next." # ->A assuming a target fo 25 fps each frame needs to be repeated 25*5 = 125 times # Assuming the frame are named 001.jpg to 400.jpg clip = ImageReader(file="E:\sequence\Wallpaper\%03d.jpg", start=1, end=400, fps=25.0/125.0, use_DeviL=true, pixel_type="RGB24") clip = clip.ChangeFPS(25) # now each frame is repeated 125 times | 5fps and thus is shown five seconds # now we add between crossfades with a length of fade_length of frame between the 5 second segments fade_length = 50 result=BlankClip(length=0, width=clip.Width(), height=clip.Height, pixel_type=clip.PixelType(), fps=clip.FrameRate(),audio_rate=0) GScript(""" for ( pos = 0, (clip.FrameCount()/125)-1, 1) { tmp = Dissolve( clip.Trim( pos*125, pos*125+fade_length/2 ), clip.Trim((pos+1)*125,(pos+1)*125+fade_length/2 ) , fade_length) result = result ++ clip.Trim( pos*125, (pos+1)*125 -1) ++ tmp ++ clip.Trim( pos*125, (pos+1)*125 -1) } """) return result
(iirc. there was a slide show maker based on Avisynth, but I forgot it's name)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
There is an Avisynth called TransAll for multiple types of transitions if you have the videos already made upmade up:
[Attachment 59942 - Click to enlarge]
The Avisynth script goes something like the following. There are many setting to change the output as you can see0
[Attachment 59941 - Click to enlarge]
The script:
Code:a=DirectShowSource("C:\Users\Bud\Desktop\test.mp4",pixel_type="yuy2").ResampleAudio(48000).Spline36Resize(852,480).ConvertFPS(29.97).trim(1,149) b=DirectShowSource("C:\Users\Bud\Desktop\test.mp4",pixel_type="yuy2").ResampleAudio(48000).Spline36Resize(852,480).ConvertFPS(29.97).trim(1,149) c=DirectShowSource("C:\Users\Bud\Desktop\test.mp4",pixel_type="yuy2").ResampleAudio(48000).Spline36Resize(852,480).ConvertFPS(29.97).trim(1,149) d=DirectShowSource("C:\Users\Bud\Desktop\test.mp4",pixel_type="yuy2").ResampleAudio(48000).Spline36Resize(852,480).ConvertFPS(29.97).trim(1,149) aa = TransPush(a,b, 59,"left") ba = TransAccord(aa , c, 59,"hor",true,false) ca = TransBubbles(ba , d, 59) vid=ca newvid = vid.ChangeFPS(29.97).Spline36Resize(854,480) newvid
Best free Windows programs for image sequence to video with crossfade
By ziptip in forum Video ConversionReplies: 0Last Post: 17th Jul 2021, 17:18 -
convert a video to 24 fps in realtime with avisynth?
By Milardo in forum Video ConversionReplies: 3Last Post: 17th Feb 2020, 22:43 -
Total failure trying to crossfade using VSDC Video Editor
By OldNick in forum EditingReplies: 4Last Post: 29th Jun 2019, 00:41 -
Need Video player with video crossfade
By khan.cross in forum Software PlayingReplies: 1Last Post: 27th Mar 2017, 20:25 -
Avisynth: Loading images like we load subtitles
By ReubenMru in forum EditingReplies: 2Last Post: 27th Jan 2017, 17:30
