Hi guys I found some old footage recorded on nokia 5630 and some glitch in the middle is it fixable and can it be made in 24 25 or 30 fps cfr only one that can open it on my pc is vlc. I look only to be more watchable I am aware it is a bad recording thanks
Media info says
General
Complete name : D:\VIDEO\Mp4\1 maj 2010 u Selo Jule.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/3gp4/isom)
File size : 4.97 MiB
Duration : 27 s 24 ms
Overall bit rate : 1 544 kb/s
Encoded date : UTC 2010-05-01 18:47:47
Tagged date : UTC 2010-05-01 18:47:47
Video
Format : MPEG-4 Visual
Format profile : Simple@L4a
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : mp4v-20
Bit rate mode : Variable
Bit rate : 1 446 kb/s
Nominal bit rate : 1 800 kb/s
Maximum bit rate : 2 000 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 10.805 FPS
Minimum frame rate : 1.149 FPS
Maximum frame rate : 30.303 FPS
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.436
Stream size : 4.66 MiB (94%)
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 26 s 197 ms
Bit rate mode : Constant
Bit rate : 96.0 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 307 KiB (6%)
Encoded date : UTC 2010-05-01 18:47:49
Tagged date : UTC 2010-05-01 18:47:49
Results 1 to 1 of 1
Mp4 Jerky, only sound in WinPhotos/Premier. File&Comp details inc
By Bustawide in forum Newbie / General discussionsReplies: 0Last Post: 28th Mar 2021, 07:00 -
Convert VFR to Image Sequence (Keeping VFR)
By Vaengence in forum EditingReplies: 11Last Post: 29th Dec 2020, 17:02 -
Encoding VFR (30 + 60 fps)
By ZetaStax in forum Video ConversionReplies: 8Last Post: 31st Jul 2020, 07:01 -
Improve quality of a mp4 file (720p)
By VideoLover in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2020, 21:00 -
Vegas to x264 mp4 with vfr - what's the best way to do it?
By Srivas in forum EditingReplies: 11Last Post: 2nd Sep 2018, 23:11
