  1. I have an MP4 file and I want to discard all content from 2:22:27 to the end. Using the command
    mp4box -splitx 0:8547 input.mp4 --alltk
    produces an MP4 file which, according to Windows Explorer, is 2:20:43 long (the first oddity; the file should be almost two minutes longer).
    Additionally, when watching the output in VLC, the timeline shows a length of 2:20:43, but the audio ends at 1:55:26 and the video ends one second later, at which point VLC closes the file automatically. According to the SRT extracted from the output MP4 with My MP4Box GUI, the subtitles end at that time as well. I want to clarify that the input file (length 2h39min) has fully uncorrupted video, audio and subtitles.
    Does anybody know what is going on here and how I can fix it?
    I am not using ffmpeg because it can't seem to handle the tx3g subtitle stream particularly well; the MP4 created by ffmpeg contains a subtitle stream but no subs are shown by VLC when activated.
    Thank you!
    Mar 2008
    Post the complete text view mediainfo report of the source file
  3. Originally Posted by davexnet View Post
    Source file:
    General
    Complete name                            : D:\input.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp42/isom/iso2/iso5/dash/avc1/dby1/mp41)
    File size                                : 5.79 GiB
    Duration                                 : 2 h 39 min
    Overall bit rate                         : 5 188 kb/s
    Video
    Format profile                           : Main@L3.2
    Format settings                          : CABAC / 2 Ref Frames
    Format settings, Reference frames        : 2 frames
    Format settings, GOP                     : M=2, N=80
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 4 554 kb/s
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 50.000 FPS
    Bits/(Pixel*Frame)                       : 0.099
    Stream size                              : 5.08 GiB (88%)
    Language                                 : German
    Codec configuration box                  : avcC
    Audio #1
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Constant
    Bit rate                                 : 128 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 145 MiB (2%)
    Language                                 : German
    Default                                  : Yes
    Alternate group                          : 1
    Audio #2
    Format                                   : E-AC-3
    Format/Info                              : Enhanced AC-3
    Commercial name                          : Dolby Digital Plus
    Codec ID                                 : ec-3
    Bit rate                                 : 256 kb/s
    Channel(s)                               : 6 channels
    Channel layout                           : L R C LFE Ls Rs
    Frame rate                               : 31.250 FPS (1536 SPF)
    Stream size                              : 292 MiB (5%)
    Language                                 : German
    Service kind                             : Complete Main
    Default                                  : No
    Alternate group                          : 1
    Text
    Format                                   : Timed Text
    Muxing mode                              : sbtl
    Codec ID                                 : tx3g
    Bit rate                                 : 131 b/s
    Stream size                              : 153 KiB (0%)
    Language                                 : German
    Default                                  : Yes
    Forced                                   : No
    Alternate group                          : 2
    And the outputted file:
    General
    Complete name                            : D:\input_0.1000_8547000.1000.mp4
    Codec ID                                 : mp42 (isom/mp42/iso2/iso5/dash/avc1/dby1/mp41)
    File size                                : 4.00 GiB
    Duration                                 : 2 h 20 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 4 067 kb/s
    Encoded date                             : UTC 2021-07-17 05:50:36
    Tagged date                              : UTC 2021-07-17 05:50:36
    Video
    Codec ID                                 : avc1
    Duration                                 : 1 h 55 min
    Bit rate                                 : 4 566 kb/s
    Maximum bit rate                         : 6 409 kb/s
    Height                                   : 720 pixels
    Stream size                              : 3.68 GiB (92%)
    Language                                 : German
    Tagged date                              : UTC 2021-07-17 05:54:00
    Audio #1
    Format                                   : AAC LC
    Bit rate mode                            : Variable
    Bit rate                                 : 127 kb/s
    Maximum bit rate                         : 147 kb/s
    Stream size                              : 105 MiB (3%)
    Language                                 : German
    Default                                  : Yes
    Alternate group                          : 1
    Audio #2
    Format                                   : E-AC-3
    Codec ID                                 : ac-3
    Bit rate                                 : 256 kb/s
    Maximum bit rate                         : 270 kb/s
    Stream size                              : 211 MiB (5%)
    Language                                 : German
    Default                                  : No
    Alternate group                          : 1
    Text
    Format                                   : Timed Text
    Muxing mode                              : sbtl
    Codec ID                                 : tx3g
    Bit rate                                 : 130 b/s
    Stream size                              : 134 KiB (0%)
    Language                                 : German
    Default                                  : Yes
    Forced                                   : No
    Alternate group                          : 2
    Mar 2008
    I don't see anything suspicious. Have you tried remuxing the whole file with ffmpeg to another mp4
    then using mp4box with the new file?
  5. Originally Posted by davexnet View Post
    I noticed that the file outputted by mp4box is exactly 4.00 GiB large, is that maybe some sort of limit for mp4box?
    Have you tried remuxing the whole file with ffmpeg to another mp4 then using mp4box with the new file?
    Unfortunately, as soon as ffmpeg "touches" my file, the subtitles become broken. I assume you are suggesting something like this?
    ffmpeg -i input.mp4 -map 0 -c copy input2.mp4
    Then input2.mp4 does not seem to have working subtitles. I have extracted the subtitle files from both input.mp4 and input2.mp4 via "mp4box -raw 4" and attached them (or you can find them here: https://we.tl/t-Jww3LmqGN8)
    Maybe somebody can see what the issue with the subtitles seems to be, because if I find a solution for that, I won't have to use mp4box for the cutting at all since ffmpeg does that just fine (save for the subtitles).
    Mar 2008
    There was this from 2016
    https://github.com/gpac/gpac/issues/680
