Hello i found my old video and it got this wierd Yellow colour. I tried to look for some fix but couldnt find anything... Any idea how to fix it or if its even possible to save this file?
Dont mind quality its over 10y old... its just that Yellow everywhere
Thx for any advice.
Did you find that on youtube by any chance ?
That is how it looks on there. It appears to have been re-encoded appr 18 months ago.
Was it meant to be upside down as well ?
I doubt if it can be fixed color-wise but then without knowing how it should look there is little hope. -
There is no blue channel.
At all.
It's gone.
Invert. Desaturate. Watch. That's all you can do.
encode subtitles into Mp4 so they can be turned on/off
By David Banner in forum EditingReplies: 7Last Post: 19th May 2021, 06:13 -
PC Screen turned static than black
By MetalKoromon in forum ComputerReplies: 1Last Post: 15th Jul 2020, 19:18 -
mp4 file has turned into a 1.4GB smaller mkv file
By JamNujo in forum Video ConversionReplies: 7Last Post: 13th May 2019, 08:44 -
Should de-interlace be turned on ?
By rodsters in forum DVD RippingReplies: 1Last Post: 1st Nov 2018, 15:12 -
yellow subtitles with ffmpeg
By lintucrowk in forum DVB / IPTVReplies: 1Last Post: 23rd Aug 2018, 18:01
